I’m cross-posting this from Programming Questions part of the forum as I did not get an answer there. Here’s hoping this part of the forum is the correct one.
Hello all,
Having made a GPS datalogger that works, I now set myself on the trail of making an new filename after each button press.
Normally, when the logger is switched on, it logs the data once a certain set of GPS parameters is met and after 10 lines, it will halt logging and blink a LED to indicate to the user it’s logged 10 lines and that the operator needs to push a button in order for the logger to start logging again.
Currently, this works without issues. Every time the button is pressed, inside loop a run once IF loop is run and the headers of each log is written to the same file (GPSDATA.CSV). After each button press, it appends to this same file.
What I want is that with each button press, a new file, incremented, is made on the SDcard, the headers written and then the rest of the code is executed, writing 10 lines and closing the file.
Before setup, I added the following declaration: char filename[13];
I’ve added this to the loop:
// create a new file
char filename[] = "GPSLOG00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
The files do get written, but they don’t possess any data other than the headers. It’ll quickly go up to 100 files but data isn’t logged although the green LED blinks.
Should I put the file-name generating into its own function? Or am I missing something with (global) variables not getting changed?
Here’s my code:
#include <SPI.h>//include library code to communicate with SPI devices
#include <SD.h>//include library code for SD card
#include <NMEAGPS.h> //the GPS library
#include <GPSport.h> //The used port configuration set for NMEAGPS
NMEAGPS gps;
const int chipSelect = 10; //SDcard is set to pin 10.
// Check configuration
#ifndef GPS_FIX_HDOP
#error You must uncomment GPS_FIX_HDOP in GPSfix_cfg.h!
#endif
//Button configuration
const int buttonPin = 2; // the number of the pushbutton pin
//LED configuration
const int blueled = 6;
const int redled = 7;
const int greenled = 5;
int ledState = LOW;
//int redState = LOW;
//int greenState = LOW;
unsigned long previousMillis = 0; //stores the last time the LED was updated
const long interval = 200; //Interval at which to blink LED
int buttonState = 0;
int counter = 0;
boolean printheaders = false; //needed for a one time run in loop
char filename[13];
pinMode(buttonPin, INPUT); //The button is used to start another logging cycle
pinMode(blueled, OUTPUT); //Blue part of the RGB Led
pinMode(redled, OUTPUT); //Red part of the RGB Led
pinMode(greenled, OUTPUT); //Green part of the RGB Led
digitalWrite(greenled, HIGH); //As I'm currently using common Anode RGB Led, this is set to High. When using common Cathode, use LOW instead.
digitalWrite(redled, HIGH); //As I'm currently using common Anode RGB Led, this is set to High. When using common Cathode, use LOW instead.
digitalWrite(blueled, HIGH); //As I'm currently using common Anode RGB Led, this is set to High. When using common Cathode, use LOW instead.
DEBUG_PORT.begin(9600);
gpsPort.begin(9600);
Serial.print("Initializing SD card...");//setup for the SD card
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present!");
digitalWrite(blueled, LOW);
digitalWrite(redled, LOW);
delay(5000);
return;
Serial.println("Card initialized.");
Serial.println("File opened. Start logging GPS data to SD card:");
//DEBUG_PORT.println
// F( "Sats HDOP Latitude Longitude Date Time Speed Heading \n"
// " (deg) (deg) \n" )
//repeat( '-', 133 );
if ((counter == 0) && (printheaders == false)) { //making sure this runs only once
printheaders = true;
if (! SD.exists(filename)) {
File dataFile = SD.open(filename, FILE_WRITE);
if (dataFile) { // if the file is available, write to it:
dataFile.println("Date, Time , Lat , Long , Sats , HDOP , Heading, Speed");//prints the headers for our data
dataFile.close();//file closed
if (gps.available( gpsPort ) && (counter <= 9)) {
gps_fix fix = gps.read();
if (fix.valid.hdop && (fix.hdop < 2000)){
bool validDT = fix.valid.date & fix.valid.time;
/* print( fix.satellites , fix.valid.satellites, 3 );
print( fix.hdop / 1000.0 , fix.valid.hdop , 6, 2 );
print( fix.latitude () , fix.valid.location , 10, 6 );
print( fix.longitude() , fix.valid.location , 11, 6 );
DEBUG_PORT.println(); */
Serial.println(filename);
digitalWrite(greenled, LOW); //data is being written to the card
if (fix.dateTime.date < 10)
dataFile.print( '0' );
dataFile.print(fix.dateTime.date);
dataFile.print( '/' );
if (fix.dateTime.month < 10)
dataFile.print(fix.dateTime.month);
dataFile.print(fix.dateTime.year);
dataFile.print(',');
if (fix.dateTime.hours < 10)
dataFile.print(fix.dateTime.hours);
dataFile.print( ':' );
if (fix.dateTime.minutes < 10)
dataFile.print(fix.dateTime.minutes);
if (fix.dateTime.seconds < 10)
dataFile.print(fix.dateTime.seconds);
dataFile.print(fix.latitude (), 10);
dataFile.print(",");
dataFile.print(fix.longitude(), 11);
dataFile.print(fix.satellites, 3);
dataFile.print(fix.hdop / 1000.0, 6);
dataFile.print(fix.heading (), 7);
dataFile.print(fix.speed_kph(), 7);
dataFile.print("\n");
dataFile.close();
//Serial.println(counter, DEC);
counter++;
else {
noFix();
else {
digitalWrite(greenled, HIGH); //Lines written, no more write actions.
if (counter >= 10){ //once 10 lines are written, called poslog, positive log to stop writing lines and wait for operator input
poslog();
void noFix() //blink the red LED to show there is no fix
//digitalWrite(greenled, HIGH);
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == HIGH) {
ledState = LOW;
ledState = HIGH;
// set the LED with the ledState of the variable:
digitalWrite(redled, ledState);
void poslog()
while (digitalRead(buttonPin) == LOW) { //Wait for the operator to press butan
counter = 0;
if (currentMillis - previousMillis >= interval) { //else, just blink the led
ledState = LOW;
else {
ledState = HIGH;
digitalWrite(blueled, ledState);
