file.print not writing to file
I have the following code:
#include <SPI.h>
#include <SD.h>
File file;  // actually use SD to open the Card and assign the file to f
  Serial.begin (9600);
  initializeSD();
  openFile ("test.txt");
  Serial.println (readLine());
  // close the file:
  closeFile();
  openFile("test.txt");
  delLine ();
  closeFile();
void initializeSD()
  Serial.println("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (SD.begin(10))
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
int writeToFile(char text[])
  if (file)
    file.println(text);
    Serial.println("Writing to file: ");
    Serial.println(text);
    return 1;
  } else
    Serial.println("Couldn't write to file");
    return 0;
void closeFile()
  if (file)
    file.close();
    Serial.println("File closed");
int openFile(char filename[])
  file = SD.open(filename);
  if (file)
    Serial.println("File opened with success!");
    return 1;
  } else
    Serial.println("Error opening file...");
    return 0;
String readLine()
  String received = "";
  char ch;
  uint32_t S = 0;
  file.seek(S);
  while (file.available())
    ch = file.read();
    if (ch == '/')
      S = S + 13;
      file.seek(S);
    else if (ch == '\n')
      return String(received);
      received += ch;
  return "";
void delLine()
uint32_t S = 0;
char ch;
    ch = file.read();
    if (ch == '/')
      S = S + 13;  // add 13 to include cr and lf on end of each line 11(+2)
      file.seek(S); //position the pointer' to where I want to overwrite
      Serial.print ("File pointer is at: ");
      Serial.println (S);
      char del[14];
      // building the overwrite line
      for(uint8_t i=0;i<11;i++) del[i]='/';
      del[11]='\r'; //  (cr)
      del[12]='\n'; // newline (lf)
      del[13]='\0'; // end of string marker;
      // over write the existing data
      file.print(del); // overwrite the data
      Serial.print(del);
the test.txt file has the following lines (11 chars per line)
THISISLINE2
THISISLINE3
THISISLINE4
THISISLINE5
my issue is that the file.print command in the delLine function is not overwriting "THISISLINE2" to /////////// which is the expected behavior. I want this functionality so that the next time the code is ran, readLine() will return THISISLINE3 since "THISISLINE2" is now "///////////".
Read somewhere that it is much easier to do this as a means of line deletion rather than having to write to a new file all the data that you want, deleting the old file and renaming the new file to match the old file.
I know it seems pretty basic but i can't get my head around it (Just started on c programming two days ago :frowning: )
any help will be greatly appreciated. thank you!
What is the default behavior of the File::open() function? Specifically, given just a file name, how is the file opened? What can you do with that file?
The term "read-only" should appear somewhere in your answer.
How can you expect to write to a read-only file?
