file transfer from arduino to raspberry pi via xbee
Hai Frds,
I am doing a water monitoring system for that the arduino collects data in data logger shield.
Now i need to transfer the file from arduino to the raspberry pi through xbee. Can you please help with this?
Thankyou
What do you need help with?
Configuring the XBees is easy, if you have the right kind. Connecting the XBee to the Arduino is easy, if you have the right shield. Connecting the XBee to the Pi isn't an Arduino issue. Opening a file is trivial. Reading from the file, and writing to the serial instance that the XBee is connected to is trivial. Closing the file when you get to the end is a no-brainer.
