hi,
i used 2 arduino boards to use one to record data on sd card and then i sent the File via uart communication protocol and store it on the second sd card on the second board but the problem on the received file that the just the first values is ok but the other values written wrong inside the file i have attached the Tx file and the received RX file .
thanks,
RX.TXT (453 Bytes)
TX.txt (3.57 KB)
