'file' was not declared in this scope
My problem is a strange one and I am unable to figure it out. I am using (attempting to use) the tinyFat library. When I make a brand new sketch and use the library, it works flawlessly. When I load their examples and compile them, it works flawlessly.
However when I go to include it in my project something goofy is happening and I cannot understand why. It will act like it cannot see the library. It gives me " 'file' was not declared in this scope" for the command res = file.initFAT(). Why would it be able to detect the library in one set of circumstances and not in another?
I would post my code but it is over 30 files in size and I am simply not doing that. As I've said, it works fine if not in this project. I have moved the project to the Arduino folder in my documents and that did nothing. Before using this library everything was working fine.
Example that works:
#include <tinyFAT.h>
#include <avr/pgmspace.h>
void setup(){
byte res = file.initFAT();
void loop(){
Move that code to the appropriate locations in my project and it explodes.
-h
I'm gussing the example has something like this:
tinyFAT file;
which is kind of important. Can you post the example and a link to the library?
This is their example and it compiles fine on my machine. There is no declaration of file in their program either.
// Demo_readLn (C)2011 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of the readLn()-function.
// This demo will open a textfile named 'TEXTFILE.TXT'
// and display its contents in the Serial Monitor.
// SD card must be connected to the SPI port of your Arduino.
// Remember to select 115200 baud in the Serial Monitor.
byte res;
word result;
char textBuffer[81];
char *verboseError(byte err)
	switch (err)
	case ERROR_MBR_READ_ERROR:
		return "Error reading MBR";
	case ERROR_MBR_SIGNATURE:
		return "MBR Signature error";
	case ERROR_MBR_INVALID_FS:
		return "Unsupported filesystem";
	case ERROR_BOOTSEC_READ_ERROR:
		return "Error reading Boot Sector";
	case ERROR_BOOTSEC_SIGNATURE:
		return "Boot Sector Signature error";
	default:
		return "Unknown error";
  // Initialize serial communication at 115200 baud
  // Initialize tinyFAT
  // You might need to select a lower speed than the default SPISPEED_HIGH
  res=file.initFAT();
  if (res!=NO_ERROR)
    Serial.print("***** ERROR: ");
    Serial.println(verboseError(res));
    while (true) {};
  Serial.println("This demo will display a textfile called 'TEXTFILE.TXT'");
  Serial.println("***** Send any character to start *****");
  while (!Serial.available()) {};
  Serial.flush();
  if (file.exists("TEXTFILE.TXT"))
    res=file.openFile("TEXTFILE.TXT", FILEMODE_TEXT_READ);
    if (res==NO_ERROR)
      result=0;
      while ((result!=EOF) and (result!=FILE_IS_EMPTY))
        result=file.readLn(textBuffer, 80);
        if (result!=FILE_IS_EMPTY)
          if (result==BUFFER_OVERFLOW)
            Serial.print(textBuffer);
            Serial.println(textBuffer);
          Serial.println("** ERROR: File is empty...");
      file.closeFile();
      switch(res)
        case ERROR_ANOTHER_FILE_OPEN:
          Serial.println("** ERROR: Another file is already open...");
        default:
          Serial.print("** ERROR: ");
          Serial.println(res, HEX);
    Serial.println("** ERROR: 'TEXTFILE.TXT' does not exist...");
  Serial.println("***** All done... *****");
Oh sorry I thought you posted code that didn't work, which is necessary. Either post your 30 file project (a link to github is great) or find a smaller example that doesn't work also. It's unlikely anyone will be able to guess at what your code is and then immediately come up with a solution.
