filename.ino as string variable
Wondering ... is it possible to use the name of the .ino file as a string variable ? (with or without full path) e.g. to Serial.print (filename)
thanks in advance !!!
There are a number of predefined constants you can use, like FILE.
@PaulS - Yes but that won't fet the .ino because of the rework the IDE does.
Mark
holmes4: @PaulS - Yes but that won't fet the .ino because of the rework the IDE does.
Mark
The value is a string. A string can be copied/manipulated. The cpp file that the IDE creates has the same name as the ino file, expect for the suffix.
Mark
Try it - I have a sketch called test.ino that I paste forum problems into to avoid accumulating a plethora of files. FILE is: /Users/username/Documents/Arduino/test/test.ino. IDE 1.6.12.
Thanks for your fast reply, guys !
Still a little confused ...
Suppose my .ino file is "123.ino"
String a = ...... ->(123.ino with or without full path) Serial.print (a);
result on COM should read 123.ino (with or without full path)
Try it and see:
  Serial.println(__FILE__);
char *a = __FILE__;
Serial.print(a);
Try to avoid big-S Strings if you can.
Edit: fixed 2 bugs in the code.
WOOT-WOOT !!! What would I do without you guys ?!? tanx, tanx, tanx !!!
this is my code :
String ino = FILE; Serial.println(FILE); Serial.println (ino);
on the serial monitor, now I read :
D:\ARDUINO SKETCH\SOLARii_MEGA190403a\SOLARii_MEGA190403a.ino D:\ARDUINO SKETCH\SOLARii_MEGA190403a\SOLARii_MEGA190403a.ino
THAT IS IT !!!
10K tanx !!!
MorganS: char *a = __FILE__; Serial.print();[/url]
You probably want to print a, not an empty string. Of course, printing something before a, so you know what a pile of characters represents, would be good, too.
I'd go with:
const char * const a = __FILE__;
or
const char a[] = __FILE__;
Alright, allright ... :) tanx again !
Although I'm already happy with the answer from wildbill, when I use this code :
  String ino = __FILE__;
  char *a = __FILE__;
  Serial.print("ino = "); [ / url];
---> the compiler tells me : "expected identifier before '/' token"...
What am I doing wrong ?
PaulVdB: What am I doing wrong ?
Not posting the complete code. Not posting the complete error message.
The code that MorganS posted was in malformed tags. That [/url] bit was not supposed to be part of the code.
Ah ! OK. 20K thanks PaulS !
My complete code (so far) is 343 lines... do you want me to post this whole thing here? I can ... no problem.
The complete error message is :
C:\Users\Paul\AppData\Local\Temp\arduino_modified_sketch_920279\SOLARii_MEGA190403a.ino: In function 'void setup()':
SOLARii_MEGA190403a:122: error: expected identifier before '/' token
C:\Users\Paul\AppData\Local\Temp\arduino_modified_sketch_920279\SOLARii_MEGA190403a.ino: In lambda function:
SOLARii_MEGA190403a:122: error: expected '{' before ';' token
122 Serial.print("ino = "); [ / url];
Using library Adafruit-GFX-Library-master at version 1.3.6 in folder: D:\ARDUINO SKETCH\libraries\Adafruit-GFX-Library-master Using library MCUFRIEND_kbv at version 2.9.8 in folder: D:\ARDUINO SKETCH\libraries\MCUFRIEND_kbv Using library DS3231 in folder: D:\ARDUINO SKETCH\libraries\DS3231 (legacy) Using library Rotary-master in folder: D:\ARDUINO SKETCH\libraries\Rotary-master (legacy) Using library SPI at version 1.0 in folder: C:\Users\Paul\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.23\libraries\SPI exit status 1 expected identifier before '/' token
do you want me to post this whole thing here? I can … no problem.
More importantly, we want you to read all the replies. I explained why your code fails to compile in reply #13.
Yes, PaulS,
I've read all the posts. (especially your post #13 !) :) (and you nailed it !) ;)
the second part of my last post (#14) was meant to be for our friend gfvalvo 8) It did seem to be odd to me that "[ / url];". I thought it might have been some code to extract ONLY the filename... So I tried it and got the message that you saw after my "quote"
I guess that there's no solution to directly get only the filename except to do some "String juggling" ... But I can do that ... VBS
Again : T H A N K S to ALL !
OK, sorry to bother you again guys ...
when I want to find the last backslash in my string (C:\Users\Paul\AppData\Local\Temp\arduino_modified_sketch_141071\SOLARii_MEGA190403a.ino)
I use
int last = (ino.lastIndexOf("\"));
but then the compiler reports :
missing terminating " character ???
I noticed that the \ character does not become blue in the code ...
hmmm ... Browsed the internet and "Arduino Cookbook" from Michael Margolis ... but so far nothing found ... Anyone ? :)
Again : 30K thanks !
Probably need an Escape Sequence.
The slash character you're using has a special meaning to the compiler. You use it to 'escape' the next character in a string. You may have used \n to get a newline for instance. Consequently, when you want an actual slash, you need two of them. So you offending line becomes
int last = (ino.lastIndexOf("\\"));
