Hello Everyone,
I am using an Arduino UNO R3 and an Adafruit GPS ultimate logger shield in my project. I am able to create files on the SD card but I do not seem to be able to write any data into those files.
The hardware setup is sound and I have used some of their sample code to successfully write some data to a file on the SD card a few times (their code has worked fine). However, I need to modify it to allow me to write different data sets into separate files on the SD card. This is where I began to expierece the difficulties I described above. The code below will create a file on the SD card but they are always empty. Any help would be greatly appreciated. Please let me know if I need to clarify anything. Thanks in advance.
#include <SPI.h>
#include <SoftwareSerial.h>
#include <SD.h>
SoftwareSerial mySerial(8, 7);
char filename[15];
char filename1[15];
// Set the pins used
#define chipSelect 10
#define ledPin 13
File logfile;
File logfile1;
pinMode(ledPin, OUTPUT);
pinMode(10, OUTPUT);
if (!SD.begin(chipSelect))
Serial.println("Card init. failed!");
strcpy(filename, "TXTFIL00.TXT");
for (uint8_t i = 0; i < 100; i++)
filename[6] = '0' + i/10;
filename[7] = '0' + i%10;
if (! SD.exists(filename))
logfile = SD.open(filename, FILE_WRITE);
if( ! logfile )
Serial.print("Couldnt create ");
Serial.println(filename);
Serial.print("Created ");
logfile.println("Test\n");
// Initialize a second File
strcpy(filename1, "TXTFIL00.TXT");
filename1[6] = '0' + i/10;
filename1[7] = '0' + i%10;
if (! SD.exists(filename1))
logfile1 = SD.open(filename1, FILE_WRITE);
if( ! logfile1 )
Serial.println(filename1);
logfile1.println("Test\n");
Serial.println("Setup Complete"); //Signifies the end of the setup function
char *firststring = "First String";
char *secondstring = "second string";
Serial.print("Writing to "); //This appears in the serial monitor when the program runs (once at the beginning) JB
// write to the first file
uint8_t stringsize = strlen(firststring);
if (stringsize != logfile.write((uint8_t *)firststring, stringsize))
logfile.flush();
logfile.write("\n");
logfile.println("firststring Please\n");
// write to the 2nd file
uint8_t stringsize1 = strlen(secondstring);
if (stringsize1 != logfile1.write((uint8_t *)firststring, stringsize1))
logfile1.flush();
logfile1.write("\n");
logfile1.println("firststring Please\n");
/* End code */
