Hi guys, I'm trying to write a code where I get a new .txt file whenever a press the reset button.
So far, I could write it deleting the old file and creating a new one, but I couldn't make it create more files, such as datalog1.txt, datalog2.txt...
Also, if I use numbers in the file's name (datalog1.txt) the code doesn't create the file and I have no idea why. ![]()
This is the code:
- A simple single freq AD9850 Arduino test script
- Original AD9851 DDS sketch by Andrew Smallbone at www.rocketnumbernine.com
- Modified for testing the inexpensive AD9850 ebay DDS modules
- Pictures and pinouts at nr8o.dhlpilotcentral.com
- 9850 datasheet at http://www.analog.com/static/imported-files/data_sheets/AD9850.pdf
- Use freely
#define W_CLK 5 // Pin 8 - connect to AD9850 module word load clock pin (CLK)
#define FQ_UD 9 // Pin 9 - connect to freq update pin (FQ)
#define DATA 6 // Pin 5 - connect to serial data load pin (DATA)
#define RESET 7 // Pin 6 - connect to reset pin (RST).
#define pulseHigh(pin) {digitalWrite(pin, HIGH); digitalWrite(pin, LOW); }
#include <SD.h>
const int chipSelect = 10;
// transfers a byte, a bit at a time, LSB first to the 9850 via serial DATA line
void tfr_byte(byte data)
for (int i=0; i<8; i++, data>>=1) {
digitalWrite(DATA, data & 0x01);
pulseHigh(W_CLK); //after each bit sent, CLK is pulsed high
// frequency calc from datasheet page 8 = * /2^32
void sendFrequency(double frequency) {
int32_t freq = frequency * 4294967295/125000000; // note 125 MHz clock on 9850
for (int b=0; b<4; b++, freq>>=8) {
tfr_byte(freq & 0xFF);
tfr_byte(0x000); // Final control byte, all 0 for 9850 chip
pulseHigh(FQ_UD); // Done! Should see output
// configure arduino data pins for output
pinMode(FQ_UD, OUTPUT);
pinMode(W_CLK, OUTPUT);
pinMode(DATA, OUTPUT);
pinMode(RESET, OUTPUT);
pulseHigh(RESET);
pulseHigh(W_CLK);
pulseHigh(FQ_UD); // this pulse enables serial mode - Datasheet page 12 figure 10
Serial.print("Initializing SD Card...");
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
if (SD.exists("DATALOG.txt")) {
SD.remove("DATALOG.txt");
else {
Serial.println("DATALOG.txt doesn't exists");
for (unsigned long fq = 30000; fq<= 50000; fq+=50) {
sendFrequency(fq); // freq
//while(1);
int sensorValue = analogRead(A0);
float dataVoltage = sensorValue * (5.0/1023.0);
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("DATALOG.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.print(dataVoltage);
dataFile.print(",");
dataFile.print(fq);
dataFile.println();
dataFile.close();
// print to the serial port too:
Serial.print(dataVoltage);
Serial.print(",");
Serial.print(fq);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening DATALOG.txt");
delay(1);
while (1) {}
Does anybody know how I can do it? I tried to define the name of the variable in the very beginning but it didn't went through.
Thanks.
