Fill with zeros a number?
Hi. Does anybody know how can I make a function that fills with zero, some number?
Like.. I have a number that goes from 0 to 360 and I would like to do like this:
i.e:
5 would be 005;
15 would be 015;
120 would be 120;
Tks in advance..
Regards
Rodrigo
The 0s are always there. You just want them to show up when printing to something?
CrossRoads:
Hi. Thank you for your asnwer.
yes.. I need the number to always have 3 digits..
Doens't matter if it is a number 1 or 10 or 200.
Here's a sample...
int foo;
char buffer[4];
  Serial.begin(19200);
  foo = 5;
  sprintf(buffer,"%03d", foo);
  Serial.println(buffer);
The second parameter is a format string. %d is decimal, %03d is decimal with three leading zeros.
I don't know if Serial.print provides any settings for that.
Could always force it I suppose:
// time to print a number
Serial.println ("printing a 3 digit number ");
if (numberToPrint <=9){
Serial.print("00");
Serial.println(numberToPrint);
if ((numberToPrint>=10) && (numberToPrint <=99)){
Serial.print("0");
if (numberToPrint>99){
lar3ry:
Here's a sample...
int foo;
char buffer[4];
  foo = 5;
Hi, Iar3ry. Thank you very much.
On Setup function it worked 100%.
I just need to now find out hot to use it as a function and uses that function to return the formated number
Thank you very much
CrossRoads:
Serial.print("00");
Serial.print("0");
Hi.. That could be an solution but I need to use this code a sa funcion so I can pass values and get the correct values returned.
@Crossroads,
Serial.print does not support this, for this the print class should be rewritten.
char buffer[4];
  Serial.println(formatForPrint(1));
  Serial.println(formatForPrint(10));
  Serial.println(formatForPrint(100));
char* formatForPrint(int foo)
  return buffer;
UKHeliBob:
char buffer[4];
  return buffer;
Thank you very much for your help. it worked.
Could you please give me some site reference about the "%03d" and what is each parameter is for?
I will apreciatte and learn more.
Thank you.
cabecinhas:
http://lmgtfy.com/?q=sprintf+reference
The code works for numbers within the rang 0..999
try the code with a number that is longer or a negative and you see some point to improve the function.
http://www.cplusplus.com/reference/cstdio/printf/
Warning: The arduino does not support all the type specifiers, specifically floating point %f and %g.
Does everything from C++ works on arduino?
If you can't afford the memory overhead of "sprintf"
if (numberToPrint < 100) {
  Serial.print("0");
if (numberToPrint < 10) {
  Serial.print("0");
Serial.print(numberToPrint);
robtillaart:
Quite right. I had meant to point that out in my reply.
In practice I would probably not use such a function in my code as it only replaces two lines with one in the main code and I would feel more in control of the formatting by having the sprintf on the line before the print instead of hidden in a function. It would also become more and more difficult to extend the function to handle other formats properly.
@UKHeliBob
It was more meant as an exercise for the OP, not as a remark on your code sec.
I've seen enough of your code to know you would implement it as you said :wink:
Don't worry. No offence taken.
Hi... Is there a way to make the "number of zeros" sent as a parameter?
I made the "total_casas " as a parameter but didn't work.
I'm new in C++. Maybe it seems to be abvious but not for me :frowning: l
char* formata_zeros_esquerda(int foo, String total_casas)
char buffer_formata_zeros_esquerda[4];
sprintf(buffer_formata_zeros_esquerda,"%0" + total_casas +"d", foo);
return buffer_formata_zeros_esquerda;
This one works but only for "3 zeros"
sprintf(buffer_formata_zeros_esquerda,"%03d", foo);
thank you very much
It doesn't work at all well for any number of zeroes.
Never return a pointer to an automatic.
However, with two "sprintf"s (the first for the format string), you could very easily support any number of zeroes.
