I am working on a strain gauge load sensor. And I want to do a signal processing by a card.
The program I want to do can be done easily on arduino.
The sensor will use a Wheatstone bridge giving me a voltage in mV / V (5mV if powered in 5V)
Voltage rather weak and I will have to use a card to amplify the signal (for example an HX711)
And then I want to get a signal out of the arduino. However arduino cards only offer PWM outputs. While I would need an analog signal.
Do you know a digital to analog converter that adapts well to the arduino PWM? Being a measurement of precision it would be necessary that the converter makes it possible to have a signal very close to the average signal sent by the PWM (<0.2% of difference).
Thank you for your answer.
I need between 2 and 6 analog outputs and these cards offer only one. That's why I planned to use the PWM.
I think to make a RC filter, but I wondered if there was not a filter already adapted and optimized for the arduino?
No, because the output voltage depends strongly on the load.
There are MUCH better ways of doing this than using the Arduino simply as a DC amplifier. Please explain why you think you need to use analog voltage output.
You have started well with specifying the output parameters required. But we need a lot more...
You said max ripple is 0.2%. Percent of what? What is the voltage range of the output?
Next most important is the speed or frequency response of the output. If you find a good tutorial online about using RC filters on PWM output, you should see that you can achieve any ripple specification by just using a very slow filter.
If you have an HX711 then it outputs digital data at extremely high resolution. Turning that back into analog is like watching a TV program on the radio. You should use the Arduino to send the digital data directly to the final analysis stage.
