Filtering an Integer array of mixed 'characters' and numbers
I have an integer array which is a mixture of characters and integer numbers (the numbers and characters could be any value - this is just an example):
int Array1[]  = {'s',250,'w',10,500,'p',15 };
I want to separate out the numbers and characters into two arrays. One of characters, and one of the integer numbers to get result:
ArrayChars[3] ...contains... {'s','w','p'}
ArrayIntNums[4] ...contains...{250,10,500,15}
The characters are commands and the numbers are data for a command. So for example {'s', 250} means "set speed to 250"
I don't even know if it is possible and I may have to store the numbers and characters in separate arrays. I think one main problem might be that some numbers and characters are interchangeable (eg 's' is also 115 and visa-versa in decimal)
Can anyone point me in the right direction?
Many Thanks
I don’t even know if it is possible
Depends. Are the odd positions in the array always letter equivalents, while the even positions are always numbers?
Makes more sense to me.
Thataway!
I think the best you could do is call them characters if in a certain range, and numbers otherwise.
0x41 to 0x5A are capital letters
0x61 to 0x7A are lowercase letters
everthing else is a number.
Your call if you want to accept other things as characters.
Na migo thisaway! :wink:
Thanks for the input PaulS.
I'll go with separate arrays.
Cheers
Thanks CrossRoads that link’s really useful - I keep it for future reference.
It is more sensible to go for separate arrays for chars and data. Then I could use other data types as well.
cheers
