Filtering CAN bus data
Hello all,
I have a question regarding programming when using a CAN bus shield. I would like to filter the data that is sent and only display certain data frames. I use the following library: GitHub - autowp/arduino-mcp2515: Arduino MCP2515 CAN interface library.
For example I would like to get only the following data frame: "18A 63C C0 0 6 D0 0".
For reading I use the following code:
#include <SPI.h>
#include <mcp2515.h>
struct can_frame canMsg;
MCP2515 mcp2515(10);
  mcp2515.reset();
  mcp2515.setBitrate(CAN_125KBPS);
  mcp2515.setNormalMode();
  Serial.println("------- CAN Read ----------");
  Serial.println("ID  DLC   DATA");
  if (mcp2515.readMessage(&canMsg) == MCP2515::ERROR_OK) {
    Serial.print(canMsg.can_id, HEX); // print ID
    Serial.print(" ");
    Serial.print(canMsg.can_dlc, HEX); // print DLC
    Serial.print(" ");
    for (int i = 0; i<canMsg.can_dlc; i++)  {  // print the data
      Serial.print(canMsg.data[i],HEX);
      Serial.print(" ");
Could you maybe help me with this?
What are you currently getting?
Currently I get about 30 different data frames. Now I would like to filter this output data to get an overview.
Please list preferably several examples of what you are getting.
Hint: the data you want always shows up in the same place.
with your main code you can simple do this! :wink:
(compiles, NOT tested!)
#include <SPI.h>
  mcp2515.reset();
    if (canMsg.can_id == 0x18A) { //printout only message frame 0x18A
      Serial.print(" ");
      Serial.print(" ");
      for (int i = 0; i < canMsg.can_dlc; i++)  { // print the data
        Serial.print(canMsg.data[i], HEX);
        Serial.print(" ");
hope that helps...
Are you using Standard (11-bit) addressing or Extended (18-bit) addressing?
I think you can filter on either the Extended Address or the Standard Address plus the first two data bytes.
