Hello :),
I'm making an countdown inside of a lot of code, and I have suspicious about the code is slowing down the millis() count because isn't processed in real-time and that's add milliseconds to the final result and that means few seconds after few minutes added to the final result.
How can its possible avoid this issue?
Thank you!
PS, code attached just in case:
// Incluir libreria
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
LiquidCrystal lcd2(8, 9, 4, 5, 6, 7);
int menuposiciones = 3;
int showed = 0;
int cancelledsauna = 0;
int timer = 2; long seconds = 0; long mlscnds = 0; int converted = 0;
int luces = 0;
int sauna = 0;
int lcd_key = 0;
int adc_key_in = 0;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
int read_LCD_buttons()
adc_key_in = analogRead(0);
if (adc_key_in > 1000) return btnNONE;
if (adc_key_in < 50) return btnRIGHT;
if (adc_key_in < 250) return btnUP;
if (adc_key_in < 450) return btnDOWN;
if (adc_key_in < 650) return btnLEFT;
if (adc_key_in < 850) return btnSELECT;
return btnNONE;
unsigned long start, finished, elapsed;
unsigned long cd_time_start, cd_time_finished, cd_time_elapsed;
pinMode(13, OUTPUT); /* Relay 4 */ // Probar
digitalWrite(13, HIGH); // Apagar
pinMode(12, OUTPUT); /* Relay 3 */ // Probar
digitalWrite(12, HIGH); // Apagar
lcd.begin(16, 2);
lcd2.begin(16, 2);
lcd.cursor();
lcd2.cursor();
//cd_time_start = millis();
// Leer botones LCD
lcd_key = read_LCD_buttons();
// Si el sauna fué cancelado avisar una sola vez y luego volver al menu principal
if( cancelledsauna == 1 )
lcd.setCursor(0,0);
lcd.print(" CANCELLED ");
lcd.noCursor();
lcd2.setCursor(0,1);
lcd2.print(" Wait... ");
lcd2.noCursor();
cancelledsauna = 0;
menuposiciones = -1;
delay(2000);
// Sauna apagado
if( sauna == 0 )
if( menuposiciones == 0 ) {
showed++;
// PANTALLA: INFO
lcd.setCursor(0,0);
lcd.print(" PRESS -- OK -- ");
lcd.noCursor();
lcd2.print(" TO START ");
lcd2.noCursor();
}else if( menuposiciones == 1 ) {
showed++;
// PANTALLA: LUCES
lcd.setCursor(0,0);
lcd.print(" L I G H T S ");
lcd.noCursor();
// Flechas arriba abajo
lcd2.print("on v off ");
lcd2.setCursor(3,1);
lcd2.write(0b01011110);
lcd2.noCursor();
if ( lcd_key == btnLEFT)
digitalWrite(13, LOW); // Encendido
if ( lcd_key == btnDOWN)
digitalWrite(13, HIGH); // Apagado
}else if( menuposiciones == 2 ) {
showed++;
// PANTALLA: TIMER
lcd.setCursor(0,0);
lcd.print("T I M E R ");
lcd.noCursor();
lcd2.print("Up v Down ");
lcd2.noCursor();
}else if( menuposiciones == 3 ) {
showed++;
// PANTALLA: SAUNA
lcd.setCursor(0,0);
lcd.print(" S A U N A ");
lcd.noCursor();
lcd2.print("on v off '");
lcd2.noCursor();
if( timer > 1 )
lcd2.setCursor(12,1);
lcd2.print(timer);
lcd2.noCursor();
}else{
lcd2.print("Inf.");
lcd2.noCursor();
digitalWrite(12, LOW); // Encendido
sauna = 1;
digitalWrite(12, HIGH); // Apagado
sauna = 0;
}else if( menuposiciones == 4 ) {
showed++;
// PANTALLA: INFO
lcd.setCursor(0,0);
lcd.print(" VERSION: 0.3.7 ");
lcd.noCursor();
lcd2.print(" ");
lcd2.noCursor();
// Posición Timer ?
lcd.setCursor(0,0);
lcd.print("T I M E R '");
// Mínimo cero
if( timer > 1 )
lcd.setCursor(12,0);
lcd.print(timer);
}else{
// Marcar como infinito
lcd.print("Inf.");
// Contról timer
if (lcd_key == btnLEFT)
// Máximo 120
if( timer < 120 )
// Subir tiempo
timer++;
lcd.setCursor(0,0);
lcd.print(timer);
delay(100);
if (lcd_key == btnDOWN)
// Mínimo cero
if( timer > 1 )
// Bajar tiempo
timer--;
lcd.setCursor(0,0);
lcd.print(timer);
delay(100);
}else{
lcd.setCursor(0,0);
lcd.print("Inf.");
if( showed != 0 )
if (lcd_key == btnRIGHT)
// Precionó Select
showed--;
// Es pantalla de info?
// Si
menuposiciones = 1;
}else{
// No
menuposiciones++;
}else{
// Sauna encendido
// Convertir minutos en segundos si es que no estaba definido
if( converted == 0 )
// No estaba definido
// Convertir minutos a segundos
seconds = timer * 60;
//seconds = 30;
mlscnds = seconds * 1000;
// Eviar que convierta de nuevo
converted++;
// Cuenta
start=millis();
finished=millis();
elapsed=finished-start;
// Calcular milisegundos restantes
//seconds = seconds - 1;
mlscnds = mlscnds - elapsed;
// Mostrar remaining (restante)
lcd.setCursor(0,0);
lcd.print("Remaining: ' ");
lcd.noCursor();
// Mostrar Milisegundos Restantes
lcd2.setCursor(11,0); // Ocultar luego (pasar a minutos)
lcd2.print(mlscnds / 1000); // Ocultar luego (pasar a minutos)
lcd2.noCursor(); // Ocultar luego (pasar a minutos)
lcd2.setCursor(0,0); // Ocultar luego (pasar a minutos)
lcd2.print(millis()); // Ocultar luego (pasar a minutos)
// Show temperature
lcd2.print("Set v:50 Now30 ");
lcd2.setCursor(8,1);
lcd2.write(0b011011111);
lcd2.setCursor(15,1);
lcd2.noCursor();
// Actualizar Timer Countdown
if( mlscnds < 1 )
converted--;
sauna = 0;
// Cancelar programa
menuposiciones = 0;
cancelledsauna = 1;
converted--;
sauna = 0;
