/var/folders/4n/gyjwfhl56m57bjyl81mmfd_h0000gn/T//ccM61GdG.ltrans0.ltrans.o: In function loop': /private/var/folders/4n/gyjwfhl56m57bjyl81mmfd_h0000gn/T/.arduinoIDE-unsaved2024413-1006-1lqqyjz.79go/sketch_may13a/sketch_may13a.ino:30: undefined reference to IRrecv::decode(decode_results*)'
collect2: error: ld returned 1 exit status
thank you for reply I've copied the code if it helps
IR Receiver Demonstration 1
IR-Rcv-Demo1.ino
Demonstrates IR codes with IR Receiver
Displays results on Serial Monitor
DroneBot Workshop 2017
http://dronebotworkshop.com
//Include IR Remote Library by Ken Shirriff
#include <IRremote.hpp>
//Define sensor pin
const int RECV_PIN = 4;
//Define IR Receiver and Results Objects
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup(){
// Serial Monitor @ 9600 baud
// Enable the IR Receiver
irrecv.enableIRIn();
void loop(){
if (irrecv.decode(&results)){
// Print Code in HEX
Serial.println(results.value, HEX);
irrecv.resume();
