Find largest element in a type
Is there a function to find the largest element in a type?
e.g.
highfunction(uint16_t) --> 65536
or
uint16_t i;
highfunction(i) --> 65536
Predefined constants would help too.
rsardu:
e.g.
or
uint16_t i;
Not that I know of. FYI, unsigned 16 bit int is 65535. You can use the calculator on your PC to check these.
Try: <cstdint> (stdint.h) - C++ Reference
On any board except AVR, you can use [
std::numeric_limits
](std::numeric_limits - cppreference.com), which is the standard way of doing this in C++.
On AVR, you’ll have to use the C macros like UINT[i]N[/i]_MAX or a third-party port of the standard library.
#include <limits>
  while (!Serial);
  Serial.println(std::numeric_limits<uint16_t>::max()); // prints 65535
void loop() {}
Pieter
Or good old limits.h, see C Library - <limits.h> - Tutorialspoint
# include <limits.h>
	int y = SCHAR_MIN;
	Serial.println(y);
HTH
a7
Sketch of Post#3 is not compiled. The error message is:
sketch_mar17b:6:53: error: macro “max” requires 2 arguments, but only 1 given
I did compile it. It works correctly for the Nano 33 BLE.
Did you compile it for AVR?
PieterP:
I have compilation error for both "Arduino UNO" and "Arduino NANO with Old Bootloader option".
GolamMostafa:
Did you read my post?
PieterP:
std::numeric_limits
On AVR, you'll have to use the C macros like UINT[i]N[/i]_MAX or a third-party port of the standard library.
Something like ui = 2^32 seems not to work.
rsardu:
That’s not a portable solution, and you’re using an XOR operator, not exponentiation: Arithmetic operators - cppreference.com
An unsigned integer of width N can't hold a value of 2^N (where '^' is to be taken as exponentiation).
What you are calling an "element" is really called a "value".
verses
UINT16_MAX
I guess “Modern C++” programmers are paid by the character :smiley:
  SerialUSB.begin(9600);
  uint64_t i;
  i = UINT32_MAX + uint64_t(1);
  SerialUSB.println(i);
Works. Thanks!
