Where I can find similar project, parts and codes ?
I think 2A step motor and simple driver + arduino ( I have ADK Mega )
Need quite big stepmotor because heavy camera stand.
JI from Finland
JI from Finland
What does "IP camera control" mean?
...R
I think it translates as camera control over WiFi or e-net.
@op Drop the stepper motor concept and look at servo controlled pan and tilt heads.
Mark
Holmes, actually industry standard PTZ cameras use stepper motors driving a belt attached to the cameras gimbal. Since the OP mentioned that the camera is heavy weight this would still be the correct approach to take. though if the manufacture of the housing and gimbal mechanism is going to be problematic for you (im lucky enough to have a metal workshop at home), then two servos may be the way forward for you particularly if you're new to all this. It would make the project a lot simpler for you.
Now that is interesting.
Mark
This one I have is out of a 27X optical Samsung Techwin PTZ Camera. good solid motor with a great resolution. quite a nice metal belt sprocket on it too.
To the OP, how much weight are you looking to control here?
Servos can move fairly heavy objects as long as the objects are neutrally balanced and mounted on bearings. Servocity has some p/t platforms for cams which might provide some construction ideas. Previous servo/joystick discussions.
Robin2:
What does "IP camera control" mean?...R
Simple turn camera left right in Place.
holmes4:
I think it translates as camera control over WiFi or e-net.@op Drop the stepper motor concept and look at servo controlled pan and tilt heads.
Mark
My Project coming this camera http://www.securitycamera2000.com/products/3-Mega-Full-HD-1080P-Network-IP-Board-Camera-Module-IR%252dCUT-CS-Lens.html with PoE. Camera and stand weight 1kg but coming long pipe end.
Camera pipe come straight motor axle. Need long motor axle.
