Find string
After I upload my data to myserver using a GET request, I then want the arduino to read the response which will indicate LED on or off. I have seen methods for reading strings where it finds a tag and then reads after it … (if someone could explain this that would be great becase the codes seem to use if line ends with. and I’m confused why they look to the end of the line… )
But anyway … if I just output a 0 or a 1 from the php do I still have to use this method or can it read that directly?
The below might be of use if a lot of data is returned to the client. If the returned data string is short, then the returned string might be captured as a c-string or a String and examined for the desired data.
http://playground.arduino.cc/Code/TextFinder
