hi guys!
i'm pretty new to the arduino-world, and also pretty new to programming...
after having successfully learned the hard basics, i now want to start my first 'real' project.
i tried to set a 'home-point' for a stepper-motor. for this i've been using a hall-sensor, which shouldn't be too hard i thought...
i used a 'do-while' loop in the void setup, which should run until the home position/magnet was detected.. from that point the real 'program' should start.
but the arduino doesn't even react to the hall sensor
the problem isn't the sensor, since it is working perfectly in an other code. so it must be the coding...
here is the code i wrote:
#include <Stepper.h>
int SPMU = 32;
Stepper myStepper(SPMU, 6,7,8,9);
const int hallPin = 12;
int hallState = 0;
myStepper.setSpeed(1000);
do {
myStepper.step(-100);
Serial.println("searching");
delay(200);
} while(hallState == LOW);
if (hallState = HIGH) {
Serial.println("found");
myStepper.step(-2458);
Serial.println("start programm");
l've been searching the internet for days now, and would be soo grateful if somebody could help me!
thank you so much in advance!
pedro
