Finding average of hardcoded values
I am trying to wrote a code to find the average of hardcoded values without hardcoding the number of vaules. This is the code i have but it gives me the average of the vaules to be 20 which is incorrect.
int a = 4;
int b = 6;
int c = 2;
int d = 8;
int num={a, b, c, d};
int numAVG = (a + b + c + d);
Serial.println(numAVG);
for (int i = 0; i < numAVG ; i++)
Your code is working fine. You need to finish the equation: int numAVG = ((a + b + c + d)/4);
What & why are you doing this ?
At first glance, it appears pointless, unless it’s simply a learning exercise.
its supposed to be a learning excersize. Im not supposed to hardcode a 4. I tried int numAVG = ((a+b+c+d)/ sizeof (num)) but i just got a 2.
Check the sizeof(num)...
You may be surprised.
i dont understand what you mean by check the sizeof(num)
Have a look at the reference page for sizeof(), particularly the "Notes and Warnings" section.
I wonder what in the world are they trying to teach with an assignment like that?
-jim lee
fdrwhy:
“check” as in “verify that the value is what you expect it to be”
Please remember to use code tags when posting code
I would declare an array of values, use a loop to add up the values, and then use the macro
#define ARRAY_SIZE(a) (sizeof(a)/sizeof((a)[0]))
to give me the number of elements of the array.
That should be enough of a hint for you to work it out.
@fdrwhy, sorry if we seem a bit obtuse, but we’re trying to teach you what’s going on... not ‘tell’ you.
sizeof() could be confusing for a beginner, because the language can be used on many different processor architectures - the beauty of a high-level language, but you really need to understand what the instructions ‘do’... not just .print(), or .begin()
How big is an int() on your processor? How big is a byte()...? floats, longs... are all different lengths on different types of cpu (well almost).
Extra points...
Is an int the same ‘size’ as an unsigned int ?
What’s the difference ?
fdrwhy:
The number of elements in an array is obtained like this:
sizeof(num)/sizeof(num[0])
as in
#define arraycount(a) (sizeof(a) / sizeof(a[0]))
My take on the problem:
int a = 4;
int b = 6;
int c = 2;
int d = 8;
int num[]={a, b, c, d};
int numAVG = 5;  // hard code the average!
// you could do this if you define the macro arraycount:
int numAVG = (a+b+c+d)/arraycount(num) ;
But its probably fragile as when you later change the code you've got to remember
to update num and numAVG in step.
The easiest solution is probably to write a function that computes the average of an array of N elements:
template <size_t N>
int average(const int (&numbers)[N]) {
    long sum = 0;
    for (int number : numbers)
        sum += number;
    long rounding = sum >= 0 ? (N / 2) : -(N / 2);
    return (sum + rounding) / long(N);
int numbers[] = {-1, -2, -3, -4, -5, -6, -7, -8, -9, -10};
int average_number = average(numbers);
Live demo: Compiler Explorer
The compiler will automatically update the average when you add or remove elements from the array.
Pieter
