Finding IRL time through computer
I currently have some code that lets me input the seconds, minutes, and hours into a function which will then change the values respectively on a clock i built. My question is if there is any way to easily synch this with real time from my computer or something. this is the current code I have which will loop through all the seconds from midnight to midnight.
Edit: I have the computer connected through the USB that you use to Upload code.
 for(int i=0; i <=86400; i++){
 int sec = i %60;
 int min = i/60 %60;
 int hr = i/60 /60 %60;
 Time_Refresh(sec,min,hr);
how does the arduino communicate with your computer or network?
just through the USB that you use to upload code, is this enough or do i need something else to do it? if so what would that be?
Just buy a real time clock module, You will find the current code will not be accurate.
yea i know that this wont be accurate forever, it is more to test if everything works. a problem with using a clock module is that I have run out of pins to use. is there a way to add extra pins?
I am using an arduino Uno and have used pins 0-13 and A0-A5
You can use external shift registers to get yourself far more pins for your LEDs, leaving some spare for a clock.
alright thank you so much!
and just to clarify using the clock module i would be able to somehow extract the seconds, minutes and hours in different integers correct?
Have the PC send HH:MM:SS.
In the sketch:
const unsigned long SECOND = 1000;
const unsigned long MINUTE = 60 * SECOND;
const unsigned long HOUR = 60 * MINUTE;
const unsigned long DAY = 24 * HOUR;
unsigned long LastDayStart = 0;
  unsigned long TimeOfDay = millis() - LastDayStart;
  int sec = (TimeOfDay / SECOND) % MINUTE;
  int min = (TimeOfDay / MINUTE) % HOUR;
  int hr = (TimeOfDay / HOUR) % DAY;
  Time_Refresh(sec, min, hr);
  if (Serial.available())
    hr = Serial.parseInt();
    min = Serial.parseInt();
    sec = Serial.parseInt();
    TimeOfDay = hr * HOUR + min * MINUTE + sec * SECOND;
    LastDayStart = millis() - TimeOfDay;
    // Clear out any line ending characters
    delay(100);
    while (Serial.available())
      Serial.read();
      delay(100);
If you don't want to use millis():
const unsigned long SECOND = 1;
  static unsigned long TimeOfDay = 0;
    delay(100);
      Serial.read();
      delay(100);
  TimeOfDay = TimeOfDay + SECOND;
An int can only go up to 32767. Try using a long instead.
