Finger-operated 3.5" Touchscreen for Arduino Uno R4 wifi?
Hi - first post here and I'll keep it brief! I've searched for a simple answer for a simple person but not clear yet.
I'm trying to find a good finger-operated colour touch screen so I can use this Arduino to show tank level data and interact with other sensors in a campervan. The alternative is the Victron Cerbo which looks clever but needs another mortgage.
Many references on this forum seem to refer to screens that I then find need a stylus, or someone says they can't get them to work.
Thanks very much for suggestions I can check out further - not precious about size.
The one I have comes with a stylus, but a finger will work. It is not a precision instrument, though, and if you want more than simple button-like options, then it could be a challenge. Mine is a bit small though, maybe 2" x 4" or less.
I would take a look at the 3.5" Nextion Discovery.
The Uno R4 will communicate with it using Serial1 on pins0/1.
Thanks - 2" x 4" is ok - buttons can be made simple - what's your screen's name?
Brilliant - thanks - that seems to have the jumper leads I need for the physical install as well.
The nextion is a better choice if mounting and wiring concerns are important, as you seem to say in post 5,
