hi we use fpm10a fingerprnt sensor and we want to send data with esp8286 in mysql but data is not avaliable. if we dont use esp8266 data send in database. but we must use esp8266. (We check rx tx pin but the problem is not solve) HELP!!
Well, we can't see your hardware (no links), your schematic (you didn't post one) or your code (you failed to post any). Nor do we know exactly what the code does, or does not do, or what you expect it to do that it doesn't, or not do that it does.
So, it's impossible to help you.
I SENT the code if you give email adress
porselen:
Post the code HERE.
