I used the one in the library,
In enrolling, when I asked to enter for valid ID, I put for example 12,
So in fingerprint.ino, I was supposed to get the value 12 right?
But it’s always 0. What’s the cause of this problem.
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
int getFingerprintIDez();
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
SoftwareSerial mySerial(11, 10);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Serial.println("fingertest");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1);
Serial.println("Waiting for valid finger...");
void loop() // run over and over again
delay(50); //don't ned to run this at full speed.
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
return finger.fingerID;
