Fingerprint scanner wont connect after power up
Hooking up a fingerprint scanner with the UNO. I have a pushbutton under the scanner which powers the circuit when pressure is put on the scanner, Idea is the circuit is only powered when your finger pushes on the scanner then opens the safe locks.
When you first open up serial monitor the readout comes up as no fingerprint scanner connected, but if you change the baud rate to 57600, let it run for a few seconds then change it back to 9600 the sensor then connects and the scanner opens the lock properly. Problem is as soon as the power is removed and reconnected the sensor doesn't work again till the baud rate is switch back and forth again. As long as power isn't removed the sensor works fine but this is not relaible because if the power ever goes out I wont be able to get into the safe.
This is an example sketch for our optical Fingerprint sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> http://www.adafruit.com/products/751
  These displays use TTL Serial to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  pinMode(9, OUTPUT);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit finger detect test");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  delay(5);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) {
      delay(1);
  Serial.println(F("Reading sensor parameters"));
  finger.getParameters();
  Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
  Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
  Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
  Serial.print(F("Security level: ")); Serial.println(finger.security_level);
  Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
  Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
  Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
  finger.getTemplateCount();
  if (finger.templateCount == 0) {
    Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
  else {
    Serial.println("Waiting for valid finger...");
    Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
void loop()                     // run over and over again
  getFingerprintID();
  delay(50);            //don't ned to run this at full speed.
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return p;
    default:
      Serial.println("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerSearch();
  if (p == FINGERPRINT_OK) {
    digitalWrite(8, HIGH);
    digitalWrite(8, LOW);
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return p;
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  digitalWrite(9, HIGH);
  delay(900);
  digitalWrite(9, LOW);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
  return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK)  return -1;
  p = finger.fingerFastSearch();
  // found a match!
Please post a link to the datasheet and the owners manual. The scanner designers can't possibly have designed the unit to use this sequence.
The sketch in post #1 comes from this library...
Sensor is a DY50, thanks xfpd you found a better spec sheet than I could find. What part do you think is out? Trying to get some ideas of where to look next, it does work just not after power up.
Chinese is not yet a tool in my toolbox. Google translate is not an option...
Downloading the library is beyond the efforts I offer.
The first link tells the baudrate used is 9600.
Paragraf 4.4 and on tells a lot of heavy stuff. Look for eventual need of setting up, initializing, the device before getting readings.
Search for application notes. They usually have examples telling "how to".
