Fingerprint sensor and servo problem
Have the Adafruit fingerprint sensor and Arduino uno and a 9 gram servo. The fingerprint sensor works great and I would like te servo to rotate 180 degrees when the fingerprint is confirmed. Have connected the servo to a separate 6volt supply and the sense wire to uno pin 9. Servo makes a little noise but does not turn. Any help would be appreciated. Here is my code:
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
#include <Servo.h>
int getFingerprintIDez();
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
SoftwareSerial mySerial(2, 3);
Servo myservo;
int pos = 0;
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
myservo.attach(9);
Serial.println(“fingertest”);
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println(“Found fingerprint sensor!”);
Serial.println(“Did not find fingerprint sensor :(”);
while (1);
Serial.println(“Waiting for valid finger…”);
void loop() // run over and over again
delay(5000); //don’t ned to run this at full speed.
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println(“Image taken”);
case FINGERPRINT_NOFINGER:
Serial.println(“No finger detected”);
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println(“Communication error”);
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println(“Imaging error”);
return p;
default:
Serial.println(“Unknown error”);
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println(“Image converted”);
case FINGERPRINT_IMAGEMESS:
Serial.println(“Image too messy”);
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println(“Could not find fingerprint features”);
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
Serial.println(“Found a print match!”);
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println(“Did not find a match”);
return p;
return p;
// found a match!
Serial.print(“Found ID #”); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
for(pos = 0; pos <= 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(5); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=0; pos-=1) // goes from 180 degrees to 0 degrees
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
// found a match!
return finger.fingerID;
Any Help?
A search for software serial and servo reveals many posts on the subject. Put your code in code tags (read the sticky).
Any Help?
Try #7 below:
http://forum.arduino.cc/index.php/topic,148850.0.html
Hi, From the picture you have not got the gnd of the servo power supply connected to the gnd of the UNO. The servo needs to see a signal with a gnd reference?
Tom.... :)
