i want to achieve this function without using adafruit fingerprint library:
i want to copy functions from this lib to my code
#include <Adafruit_Fingerprint.h>
#define mySerial Serial2
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
finger.begin(57600);
delay(5);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
Serial.println(F("Reading sensor parameters"));
finger.getParameters();
Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
Serial.print(F("Security level: ")); Serial.println(finger.security_level);
Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
void loop() // run over and over again
// LED fully on
finger.LEDcontrol(FINGERPRINT_LED_ON, 0, FINGERPRINT_LED_RED);
delay(250);
finger.LEDcontrol(FINGERPRINT_LED_ON, 0, FINGERPRINT_LED_BLUE);
delay(250);
finger.LEDcontrol(FINGERPRINT_LED_ON, 0, FINGERPRINT_LED_PURPLE);
delay(250);
// flash red LED
finger.LEDcontrol(FINGERPRINT_LED_FLASHING, 25, FINGERPRINT_LED_RED, 10);
delay(2000);
// Breathe blue LED till we say to stop
finger.LEDcontrol(FINGERPRINT_LED_BREATHING, 100, FINGERPRINT_LED_BLUE);
delay(3000);
finger.LEDcontrol(FINGERPRINT_LED_GRADUAL_ON, 200, FINGERPRINT_LED_PURPLE);
delay(2000);
finger.LEDcontrol(FINGERPRINT_LED_GRADUAL_OFF, 200, FINGERPRINT_LED_PURPLE);
delay(2000);
so i want a to build a code like this:
#include <HardwareSerial.h>
// Define commands and constants
uint32_t password = 0xFFFFFFFF; // Replace with your fingerprint sensor password
#define FINGERPRINT_VERIFYPASSWORD 0x13
#define FINGERPRINT_OK 0x00
#define FINGERPRINT_PACKETRECIEVEERR 0x01
#define FINGERPRINT_TEMPLATECOUNT 0x1D //!< Read finger template numbers
#define FINGERPRINT_AURALEDCONFIG 0x35 //!< Aura LED control
#define FINGERPRINT_LEDON 0x50 //!< Turn on the onboard LED
#define FINGERPRINT_LEDOFF 0x51 //!< Turn off the onboard LED
#define FINGERPRINT_LED_BREATHING 0x01 //!< Breathing light
#define FINGERPRINT_LED_FLASHING 0x02 //!< Flashing light
#define FINGERPRINT_LED_ON 0x03 //!< Always on
#define FINGERPRINT_LED_OFF 0x04 //!< Always off
#define FINGERPRINT_LED_GRADUAL_ON 0x05 //!< Gradually on
#define FINGERPRINT_LED_GRADUAL_OFF 0x06 //!< Gradually off
#define FINGERPRINT_LED_RED 0x01 //!< Red LED
#define FINGERPRINT_LED_BLUE 0x02 //!< Blue LED
#define FINGERPRINT_LED_PURPLE 0x03 //!< Purple LEDpassword
#define FINGERPRINT_REG_ADDR_ERROR 0x1A //!< shows register address error
#define FINGERPRINT_WRITE_REG 0x0E //!< Write system register instruction
Serial2.begin(57600, SERIAL_8N1, 16, 17); // 8 data bits, no parity, 1 stop bit
if (verifyPassword(password)) {
Serial.println("Password verified!");
Serial.println("Password verification failed!");
// Function to verify the fingerprint sensor's password
boolean verifyPassword() {
// Function to send a command packet to the fingerprint sensor
void sendCommandPacket(){
void getParameters(){
void LEDcontrol(){
Can u write me an example for
and ill try to do others
