Fingerprint sensor does not work in mega
Hello,I’m trying to get the enrollment using adafruit enrollment example in arduino mega 2560.but my finger print sensor is 6 pins one.I searched internet and find these pins for 4 pins related to vin rx tx gnd
the code I used is this and use 0,1 pin for rx tx as in the image
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
uint8_t id;
uint8_t getFingerprintEnroll();
// Software serial for when you dont have a hardware serial port
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// On Leonardo/Micro/Yun, use pins 8 & 9. On Mega, just grab a hardware serialport
SoftwareSerial mySerial(0,1);
//Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
// On Leonardo/Micro or others with hardware serial, use those! #0 is green wire, #1 is white
//Adafruit_Fingerprint finger = Adafruit_Fingerprint(&Serial1);
while (!Serial); // For Yun/Leo/Micro/Zero/…
Serial.println(“Adafruit Fingerprint sensor enrollment”);
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println(“Found fingerprint sensor!”);
Serial.println(“Did not find fingerprint sensor :(”);
while (1);
uint8_t readnumber(void) {
uint8_t num = 0;
boolean validnum = false;
while (1) {
while (! Serial.available());
char c = Serial.read();
if (isdigit(c)) {
num *= 10;
num += c - ‘0’;
validnum = true;
} else if (validnum) {
return num;
void loop() // run over and over again
Serial.println(“Ready to enroll a fingerprint! Please Type in the ID # you want to save this finger as…”);
id = readnumber();
Serial.print(“Enrolling ID #”);
Serial.println(id);
while (! getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
int p = -1;
Serial.print(“Waiting for valid finger to enroll as #”); Serial.println(id);
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println(“Image taken”);
case FINGERPRINT_NOFINGER:
Serial.println(".");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println(“Communication error”);
case FINGERPRINT_IMAGEFAIL:
Serial.println(“Imaging error”);
default:
Serial.println(“Unknown error”);
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println(“Image converted”);
case FINGERPRINT_IMAGEMESS:
Serial.println(“Image too messy”);
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println(“Could not find fingerprint features”);
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println(“Remove finger”);
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print(“ID “); Serial.println(id);
p = -1;
Serial.println(“Place same finger again”);
switch (p) {
Serial.print(”.”);
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print(“Creating model for #”); Serial.println(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println(“Prints matched!”);
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println(“Fingerprints did not match”);
return p;
return p;
Serial.print("ID "); Serial.println(id);
p = finger.storeModel(id);
Serial.println(“Stored!”);
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println(“Could not store in that location”);
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println(“Error writing to flash”);
return p;
return p;
…but problem is when I having connected pins to the arduino.nothing happens in finger print sensor(not even lights on it).I doubt that finger print sensor is not working…it shows that in the serial moniter “Did not find fingerprint sensor :(”. can someone help me to fix the problem.
You can NOT use pins 0 and 1 for hardware serial (Serial) and software serial (mySerial) at the same time.
There is NO excuse for using SoftwareSerial on the Mega, while NOT using three of the hardware serial ports.
You have commented out both variations of the finger instance variable. I doubt that the code the you improperly posted will even compile. I know for a fact that it will NOT work.
