Hello everybody, I have previously made a post regarding my fingerprint sensor. Unfortunately, my issue has not been solved. I am making a PC Login device with the fingerprint sensor which simply inputs a Keyboard.print with the password.
With this, in the serial monitor it seems to only read out the confidence as one number and give back on only ID # as 0 even though it is registered as something different.
Below is a pic of the serial monitor and the code. Thank you.
P.S It may be worth noting I am using an Arduino Pro Micro (Leanardo)
#include <Adafruit_Fingerprint.h>
#include <Keyboard.h>
SoftwareSerial mySerial(10, 16);
char Escape;
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
#else
#define mySerial Serial1
#endif.
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Keyboard.begin();
while (!Serial);
delay(100);
Serial.println("Finding fingerprint sensor...");
finger.begin(57600);
delay(5);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) {
delay(1);
Serial.println(F("Reading sensor parameters"));
finger.getParameters();
Serial.print(F("Status: 0x")); Serial.println(finger.status_reg, HEX);
Serial.print(F("Sys ID: 0x")); Serial.println(finger.system_id, HEX);
Serial.print(F("Capacity: ")); Serial.println(finger.capacity);
Serial.print(F("Security level: ")); Serial.println(finger.security_level);
Serial.print(F("Device address: ")); Serial.println(finger.device_addr, HEX);
Serial.print(F("Packet len: ")); Serial.println(finger.packet_len);
Serial.print(F("Baud rate: ")); Serial.println(finger.baud_rate);
finger.getTemplateCount();
if (finger.templateCount == 0) {
Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
else {
Serial.println("Waiting for valid finger...");
Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
void loop() // run repeatedly
getFingerprintID();
delay(50);
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
p = finger.fingerSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// Finger Match
Serial.print("Found ID #"); Serial.print(finger.fingerID);
Serial.print(" with confidence of "); Serial.println(finger.confidence);
return finger.fingerID;
//once ID #0 is found, print password and release keys
if (Serial.print("Found ID #")) {
Keyboard.begin();
delay(2000);
Keyboard.print("PASSWORD");
delay(2000);
return finger.fingerID;;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
p = finger.fingerFastSearch();
