Hi there,
My friends just give me a fingerprints sensor for my birthday but it had six cable of different color. I see different tutorial about the sensor with four cable but when I tried some of them they don't work with my sensor. I think it's because I don't use two (the yellow and the blue) of the six cable.
This is the datasheet of the sensorhttp://osoyoo.com/driver/Fingerprint%20user%20manual.pdf but I don't understand it very well.
The problem is that I don't know how to use the two cable (yellow and blue ones).
I'm using an Arduino Uno R3 and the Arduino IDE is the last version, I don't think it is important but I'm using Ubuntu 16.04.
This is the code I have tried without success:
#include <peng_fei_Fingerprint.h>
#include <SoftwareSerial.h>
uint8_t getFingerprintEnroll(uint8_t id);
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
SoftwareSerial mySerial(2, 3);
peng_fei_Fingerprint finger = peng_fei_Fingerprint(&mySerial);
Serial.println("fingertest");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor !!!!");
while (1);
void loop() // run over and over again
Serial.println("Type in the ID # you want to save this finger as...");
uint8_t id = 0;
while (true) {
while (! Serial.available());
char c = Serial.read();
if (! isdigit(c)) break;
id *= 10;
id += c - '0';
Serial.print("Enrolling ID #");
Serial.println(id);
while (! getFingerprintEnroll(id) );
uint8_t getFingerprintEnroll(uint8_t id) {
uint8_t p = -1;
Serial.println("Waiting for valid finger to enroll");
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
Serial.println(".");
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
default:
Serial.println("Unknown error");
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
p = -1;
Serial.println("Place same finger again");
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
return p;
I have found it here http://kookye.com/2016/07/24/use-arduino-drive-fingerprint-sensor/.
The error I get is "Did not find fingerprint sensor".
In attachment there is a photo of the sensor with the wires.
Thank everybody for the help in advance and I' m a newbie on Arduino so please don't get angry if I ask obvious question.
