# FINISHED PROJECT: ATTiny13A DMX Receiver, to WS2813 LED controller in 962 bytes
**URL:** <https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845>\
**Category:** Showcase\
**Created:** [November 11, 2014, 7:59am UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845 "2014-11-11T07:59:27Z")\
**Posts on this page:** 20\
**Page:** 1
<div class="post-metadata">
**Author:** ![mcnobby](https://avatars.discourse-cdn.com/v4/letter/m/f9ae1b/32.png) [@mcnobby](https://forum.arduino.cc/u/mcnobby)\
**Post date:** [November 11, 2014, 7:59am UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/1 "2014-11-11T07:59:27Z")
</div>
Hi All,
I thought I would publish this for all those who are interested in DMX and those clever little WS2812 RGB leds
Its written to fit in an ATTiny13A which has 1k of flash space and 64 bytes of Ram
```cpp
ATTINY13 - DMX512-Receiver to 4 x WS2812 driver - 9.6mhz - 962 bytes
LED to show that DMX data is being received
Up/Down buttons to select DMX RX channel - both held will reset channel to 1
Channel saved to EEprom
Requires 75176 differential transceiver chip to interface DMX to ATTiny13
Get tiny13 cores -> http://forum.arduino.cc/index.php?topic=89781.0
boards.txt entries :
attiny13at9.name=ATtiny13 @ 9.6MHz (internal 9.6 MHz clock)
attiny13at9.bootloader.low_fuses=0x3a
attiny13at9.bootloader.high_fuses=0xff
attiny13at9.upload.maximum_size=1024
attiny13at9.build.mcu=attiny13
attiny13at9.build.f_cpu=1200000
attiny13at9.build.core=core13
                 RESET 1 -     - 8 VCC
     DEBUG/LED/A3/Pin3 2 -     - 7 Pin2/A1/SCK/WS2812 data
  DMXin+/DMXin/A2/Pin4 3 -     - 6 Pin1/MISO/PWM/CHANUP button to 0v
                   GND 4 -     - 5 Pin0/MOSI/PWM/CHANDN button to 0v
#include <avr/eeprom.h>
#define WAIT_FOR_BREAK_START 0
#define WAIT_FOR_START_BIT 1
// Pin definitions
#define DMX_IN 4 // PortB4 = actual pin 3 on chip
#define INPUT_PULLUPS 0b00000011 // pin 0 & 1 for pull ups only
#define UP_KEY 0b00000010
#define DN_KEY 0b00000001
#define KEYS   0b00000011
#define DEBUG_PIN 0b10000000
#define LED_MASK 0b00001000
// precise timings etc
#define MAXCHANNELS 512
#define PINMASK 0b00010000
#define DEBOUNCE 100 // debounce time in micros
// WS2812 specific
#define DIGITAL_PIN   (2)         // Digital port number
#define PORT          (PORTB)     // Digital pin's port
#define PORT_PIN      (PORTB2)    // Digital pin's bit position
#define DMX_PIN       (PORTB4)
#define NUM_CHANS     (13)
uint8_t lastRaw, key; // 2 bytes (2)
uint8_t rxData, state, chCount, x, LED_count; // 5 bytes (7) // flags,
unsigned long keyTime; // 4 bytes (11)
uint16_t DMXstart, rxCount; // 4 bytes (15)
uint8_t dmxData[NUM_CHANS];
void setup(void) {
  DDRB |= 0b00001100; // set data direction for debug etc
  PORTB |= INPUT_PULLUPS; // used when setting key inputs
  // EEPROM INIT (if uninitialsed, then init !)
  if ( eeprom_read_byte((unsigned char *) 2) ) {
    eeprom_write_byte((unsigned char *) 2, 0 ); EEPROMwrite(1);
  // READ EEPROM
  DMXstart = eeprom_read_byte((unsigned char *) 0) + ( eeprom_read_byte((unsigned char *) 1) <<8 );
  cli();
  WS2812(); // clear LEDs
void loop(void) {
  cli();
  switch (state) {
    case WAIT_FOR_BREAK_START:
      asm ( "L_%=:\n\t" "sbic %0, %1\n\t" "rjmp L_%=\n\t" :: "I" (_SFR_IO_ADDR(PORT)), "I" (DMX_PIN)  ); // wait for break to start (HIGH->LOW)
      chCount = 0;
      while (chCount < 22 ) { // this value should really be <22 to measure 88us
        asm ("ldi %0,8\n break:\n dec %0\n brne break\n" :: "r" (8) ); // to give a 4us loop
        if (PINB & PINMASK) { chCount=0; }  // if High then reset count
        else { chCount++; }
      while (!(PINB & PINMASK)) { }  // wait for break to expire
      if (!LED_count--) { // heartbeat indicator
        PORTB ^= LED_MASK; LED_count=16;
      rxCount = chCount = 0; // reset byte counter
      state = WAIT_FOR_START_BIT; // set next state
    case WAIT_FOR_START_BIT:
      while (PINB & PINMASK) { } // wait while input is high
      uint8_t m=1; // start bit mask at 0b00000001
      asm ("here1:\n dec %0\n brne here1\n" :: "r" (5) ); // delay to align sample of first bit
      for (x=0; x<8; x++) {
        asm ("ldi %0,7\n nop\n nop\n bits:\n dec %0\n brne bits\n" :: "r" (7) );
        // the above line may require adjustment for internal resonator
        // generally the 2 x NOPs work, but I have seen some requiring either one NOP or even NONE
        PORTB |= DEBUG_PIN; // do not remove
        if (PINB & PINMASK) { rxData |= m; }
        if (!(PINB & PINMASK)) { rxData &= ~m; }
        m <<= 1; // shift mask right
        PORTB &= ~DEBUG_PIN; // do not remove
      asm ("stop:\n dec %0\n brne stop\n" :: "r" (5) ); // post bit read delay, wait for stop bits
      if ( (PINB & PINMASK) && (chCount <= NUM_CHANS) ) { // stop bit found ?
          if ( rxCount >= DMXstart )  { dmxData[++chCount] = rxData; } // ensure captured channel is in our range
          rxCount++; // get next byte
          state = WAIT_FOR_START_BIT; // go and grab next byte
      // if you get to here then all required channels have been captured, so dump rest of packet and do WS2812 stuff
      else {
        uint8_t t; for (x=1; x<NUM_CHANS; x+=3) {
          t=dmxData[x+1]; dmxData[x+1]=dmxData[x]; dmxData[x]=t; // rearrange RGB input to GRB for WS2812
        WS2812(); // output data to devices
        state = WAIT_FOR_BREAK_START; // start all over again
void WS2812(void) {
  for (volatile uint8_t y=1; y<NUM_CHANS; y++) {
      asm volatile(
          "ldi  %3, 8\n\t"      // reset number of bits
        "nextbit:\n\t"          // label
          "sbi  %0, %1\n\t"     // SET OUTPUT HIGH
          "sbrs %4, 7\n\t"      // Skip output low if HiBit in value is set
          "cbi %0, %1\n\t"      // SET OUTPUT LOW, early for a low
          "sbrc %4, 7\n\t"      // Skip output low if HiBit in value is clear
          "cbi %0, %1\n\t"      // SET OUTPUT LOW, late for a high
          "rol  %4\n\t"         // shift value left to get to next bit
          "dec  %3\n\t"         // decrement nBits
          "brne nextbit\n\t"    // branch if bits not finished
          // Input operands         Operand Id (w/ constraint)
          "I" (_SFR_IO_ADDR(PORT)), // %0
          "I" (PORT_PIN),           // %1
          "e" (&PORT),              // %a2
          "r" (8),                  // %3
          "r" (dmxData[y])          // %4
        ); // asm
    } // x loop
    readKeys();
void readKeys(void) {
    uint8_t raw = ~PINB & KEYS; // read key in reverse
    if (raw != lastRaw) {
     keyTime = micros();
    if ((micros() - keyTime) > DEBOUNCE && raw != key) {
      key = raw;
      if ( key == KEYS ) {
        EEPROMwrite(1); // reset DMX channel to 1
      if ( (key == DN_KEY) && DMXstart > 1) {
        EEPROMwrite(--DMXstart); // decrease DMX channel & save
      if ( (key == UP_KEY) && DMXstart < (uint16_t) (MAXCHANNELS - NUM_CHANS) ) {
        EEPROMwrite(++DMXstart); // increase DMX channel & save
    lastRaw = raw;
void EEPROMwrite(uint16_t val) {
  eeprom_write_byte((unsigned char *) 0, val);
  eeprom_write_byte((unsigned char *) 1, val>>8);
Regards, Bob
**Post date:** [November 11, 2014, 8:26am UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/2 "2014-11-11T08:26:57Z")
</div>
Video [HERE](https://www.youtube.com/watch?v=Krsjzqjq9h0)
**Post date:** [November 18, 2014, 8:11am UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/3 "2014-11-18T08:11:47Z")
</div>
Perhaps I should upload a circuit diagram, I shall do one !
**Author:** ![Genesis92](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/genesis92/32/217805_2.png) [@Genesis92](https://forum.arduino.cc/u/Genesis92)\
**Post date:** [November 18, 2014, 9:22pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/4 "2014-11-18T21:22:30Z")
</div>
great and interesting 🙂
The internal 9.6Mhz clock is ok over temperature range to have good timings for the DMX speed and asynchronous WS2812 chips?
**Post date:** [November 19, 2014, 8:02am UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/5 "2014-11-19T08:02:08Z")
</div>
> Genesis92:
The WS2812 are fine, but I have found the DMX can be a bit flakey over temperature and even some t13 chips are different to others... in saying that you get a lot of bang for your buck with this code.. its just a bit of fun.. I managed to make 10 working boards that seemed reasonably stable, although some of them needed tweaking timing wise (see notes in code) - really this should be done using the bits that can finely adjust the resonator frequency
**Post date:** [November 19, 2014, 9:30am UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/6 "2014-11-19T09:30:54Z")
</div>
ok 🙂
**Post date:** [November 19, 2014, 3:37pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/7 "2014-11-19T15:37:43Z")
</div>
and thanks for your interest Genesis 🙂
**Author:** ![Bianco](https://avatars.discourse-cdn.com/v4/letter/b/dec6dc/32.png) [@Bianco](https://forum.arduino.cc/u/Bianco)\
**Post date:** [December 29, 2014, 8:10pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/8 "2014-12-29T20:10:57Z")
</div>
Have you tried using main() and while(1) rather than setup() and loop()?
It saves a few hundred bytes in some situations.
**Author:** ![smeezekitty](https://avatars.discourse-cdn.com/v4/letter/s/c4cdca/32.png) [@smeezekitty](https://forum.arduino.cc/u/smeezekitty)\
**Post date:** [December 30, 2014, 7:29am UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/9 "2014-12-30T07:29:47Z")
</div>
Without setup(), many of the core functions won't work.
**Post date:** [December 30, 2014, 7:48am UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/10 "2014-12-30T07:48:38Z")
</div>
There have been several occasions where I have had to use main() instead of loop() etc, I think it may have had something to do with hijacking timer0 (on other projects).
I have had to go the main() route on [THIS](http://forum.arduino.cc/index.php?topic=288766.0;topicseen) project, not only to save bytes, but it seemed to be the only way to solve a \_vector error that I couldnt trace.. I think I looked it up on line somewhere and the suggestion was to move to main(), and by doing that I didnt noticd any loss in core functions as I write a fair amount in asm these days
**Post date:** [December 31, 2014, 5:58pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/11 "2014-12-31T17:58:44Z")
</div>
> smeezekitty:
They will if you include the libraries, won't they?
**Author:** ![tmaceng](https://avatars.discourse-cdn.com/v4/letter/t/e9bcb4/32.png) [@tmaceng](https://forum.arduino.cc/u/tmaceng)\
**Post date:** [May 26, 2015, 7:21pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/12 "2015-05-26T19:21:46Z")
</div>
You mentioned a circuit diagram. Do you have one? Board layout? Thanks for sharing. I would like to experiment with this for my christmas display 2015.
**Post date:** [May 26, 2015, 8:10pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/13 "2015-05-26T20:10:38Z")
</div>
The circuit is very simple with the main connections being here
```cpp
                RESET 1 -    - 8 VCC
I do have a board layout too, I shall dig that out and perhaps do a full schematic 🙂
**Author:** ![vaibhavphale](https://avatars.discourse-cdn.com/v4/letter/v/ba8739/32.png) [@vaibhavphale](https://forum.arduino.cc/u/vaibhavphale)\
**Post date:** [December 1, 2015, 5:21am UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/14 "2015-12-01T05:21:29Z")
</div>
Hi friends. I need a circuit diagram of this project. Can you please provide it to me?
**Post date:** [December 1, 2015, 1:40pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/15 "2015-12-01T13:40:53Z")
</div>
I made a PCB if that would help ?
**Post date:** [December 1, 2015, 5:20pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/16 "2015-12-01T17:20:47Z")
</div>
OK sir
**Post date:** [December 2, 2015, 12:14pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/17 "2015-12-02T12:14:51Z")
</div>
There is a far better solution to serial reception than the above, it relies on counting cycles between leading edges of the received bits, and when a bit changes state within a 'window' the syncronisation is reset. With this application is it very useful as I have found that temperature and differences in ATTiny13's effect the clock somewhat and sometimes get data errors.
So either a resync on each bit is good (but tricky to implement) or a sync on the startbit of each byte only may be better
I have only written this approach in spec form and not coded yet, but it is on my list, and I am hoping it will still fit into the \<1k bytes
This current application works by this method
1. lock onto start of DMX stream
2. read just enough bits/bytes that we need, then and stop reading
3. write serial data to the serial LEDs
4. the current DMX frame will still be streaming here but ignore it go back to (1)
I am not a big fan of coding like this, I prefer interrupts, but sometimes you have to break the rules, especially when you are trying to sniff data at 250kbps and write to LEDs at 800KHz !!
**Post date:** [December 2, 2015, 12:16pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/18 "2015-12-02T12:16:30Z")
</div>
To be honest the whole code would be better written in assembler rather than dodging in and out of C all the time, it would probably run more accurate and efficient too
this would be one C-code file with the assembler embedded in, and would happily run in the Arduino environment, so nothing special to do apart from write using USBISP
**Post date:** [June 2, 2016, 12:45pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/19 "2016-06-02T12:45:43Z")
</div>
I have rewritten this code to efficiently decode DMX512, all in assembler
using the internal 9.6MHz resonator, and accurate sample points, start/stop bit detection, Break and MAB detection, and error detection.
Currently using this to try and write to a much larger string of WS2812 LEDs, but the limitation is RAM (60bytes). I tried to slow the WS writes down so that they fell in-line with RX speed of the DMX bytes, but this is too slow for the WS chips and they seem to do their own thing !!
Nevertheless, I have a good solid DMX receiver
Just wondering what projects I can use this simple/cheap/small device on
DMX switch/relay ?
Any suggestions ??
**Author:** ![imayoda](https://avatars.discourse-cdn.com/v4/letter/i/77aa72/32.png) [@imayoda](https://forum.arduino.cc/u/imayoda)\
**Post date:** [July 20, 2016, 12:44pm UTC](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845/20 "2016-07-20T12:44:31Z")
</div>
Nice job for this, but asm is not in my chords (yet) unfortunately 🙂
I've seen lots of cinese commercial products like rgb pars (many watts) using overpowered stm8 mcus, similar in power to the 328p.
Open source tiny code is state of art for receivers, i'm trying myself to make custom pars or scene lights with cheaper and smaller avr.
kudos to you
[Next page](https://forum.arduino.cc/t/finished-project-attiny13a-dmx-receiver-to-ws2813-led-controller-in-962-bytes/268845.md?page=2)
