Finite State Machine question
I have written code to turn on a random LED using a pushbutton and I am trying to work out how to use a FSM to turn each LED off after a specified time.
#include <FastLED.h>
#include <Bounce.h>
#define numLEDs 50
#define ledPin 2
struct CRGB leds[numLEDs];
const int buttonPin = 3;
Bounce pushbutton = Bounce(buttonPin, 10);  // 10 ms debounce
int ledNumber;
int isLedStatus[numLEDs];                   // 0=off, 1=on, 2=fading
unsigned long onTime = 5000;                // time LED is on
  pinMode(buttonPin, INPUT_PULLUP);
  FastLED.addLeds<WS2811, ledPin, RGB>(leds, numLEDs);
  randomSeed(analogRead(0));
byte previousState = HIGH;
void turnOnCandle()
    leds[ledNumber] = CRGB::Red;
    isLedStatus[ledNumber] = 1;
    FastLED.show();
    Serial.print("LED number: ");
    Serial.println(ledNumber);
void doRandomCandle()
  do
    ledNumber = random(0, numLEDs);
  while (isLedStatus[ledNumber] != 0);
  turnOnCandle();
  if (pushbutton.update()) {
    if (pushbutton.fallingEdge()) {
      doRandomCandle();
I can make an array that records the time each LED was turned on using Millis() but I can’t work out how to check how the time of each one is doing against my onTime to turn it off again.
I have been reading lots of tutorials and examples of finite state machines, but I can’t find out anywhere that talks about tracking an array of objects.
Is this possible?
Thanks,
Rob
unsigned long onTimes[numLEDs];
   // Some code to turn pins on and set onTimes[n] for the nth pin
   unsigned long now = millis();
   for(byte b=0; b<numLEDs; b++)
      if(now - onTimes[b] > desiredOnTime)
         // Quit wasting energy; turn the damned lights off!
No state machines were harmed in the making of this code (snippet).
#include <Fsm.h>
#include <Bounce.h>
#define numLEDs 50
#define ledPin 2
int ledNumber;
unsigned long isLedOnTimes[numLEDs];               // millis() at switching on LED
unsigned long onTime = 5000;                         // interval after which to fade (milliseconds)
  // Serial.begin(9600);
void turnOnCandle()
  isLedOnTimes[numLEDs] = millis();
  FastLED.show();
void fadeOutCandle()
  leds[ledNumber] = CRGB::Black;
  isLedStatus[ledNumber] = 0;
  FastLED.show();
  do
  turnOnCandle();
      doRandomCandle();
  for (byte b = 0; b < numLEDs; b++)
    if (now - isLedOnTimes[b] > onTime)
      fadeOutCandle();
I’m not sure if have implemented your suggestion correctly as it is doing some very weird things… The first time I hit the button, the LED goes off after 5 seconds as planned. Subsequent LEDs flash on for a split second only.
If I hit the button multiple times before the first 5 seconds have elapsed, none of them go off, but then after 5 seconds have elapsed subsequent ones flash on for a split second.
It’s important that an LED can be turned on at any time and will still go off after x seconds. Eventually I will add in further complexity, to fade the LED out over 5 seconds after it has been on for 60 seconds.
Sorry it was well past my bed time last night and I see a mistake I made this morning.
void turnOnCandle()
  FastLED.show();
Should be:
void turnOnCandle()
  isLedOnTimes[ledNumber] = millis();
  FastLED.show();
I have also changed:
  isLedStatus[ledNumber] = 0;  // added to reset the time of LED after it has been switched off
  FastLED.show();
Here is the new code in total, but it’s still not working as planned. LEDs now blink on for a split second each, without waiting for the onTime before switching off.
#include <Fsm.h>
#include <Bounce.h>
#define numLEDs 50
#define ledPin 2
int ledNumber;
void turnOnCandle()
  FastLED.show();
  isLedOnTimes[ledNumber] = 0;
  FastLED.show();
  do
  turnOnCandle();
      doRandomCandle();
    if (currentMillis - isLedOnTimes[b] > onTime)
      fadeOutCandle();
I’m probably missing something simple, btu any advice would be great. Thanks!
I should have tried a bit more before replying.
This code works as planned. Woop Woop, now time to go to work :!
#include <Fsm.h>
#include <Bounce.h>
#define numLEDs 50
#define ledPin 2
int ledNumber;
unsigned long onTime = 10000;                         // interval after which to fade (milliseconds)
void turnOnCandle()
  FastLED.show();
void fadeOutCandle(byte turnOffLED)
  leds[turnOffLED] = CRGB::Black;
  isLedStatus[turnOffLED] = 0;
  isLedOnTimes[turnOffLED] = 0;
  FastLED.show();
  do
  turnOnCandle();
      doRandomCandle();
      fadeOutCandle(b);
