Fio constantly resets
I have 2 Fio boards with which I’m trying to cross communicate (for test puposes) a switch being pressed. The intent is to press a momentary switch and see a local LED light up AND an LED on the other Fio. The same should happen on the other Fio. The software is identical on both.
It seems to work but quickly starts a back and forth reset of the 2 Fio boards.
I’ve seen notes about halting the resets on a basic arduino by putting a 120 ohm resister between reset and VCC; or a capacitor. But I have not seen how it’s done on the Fio.
Anyone have any tips about how to stop the Fio from resetting when I send a signal from Fio serial to Fio serial?
Thanks in advance,
Chris.
XBee 1
PAN ID: 1111
DH: 0
DL: 12
MY: 11 (radio 17)
XBee 2
PAN ID: 1111
DH: 0
DL: 11
MY: 12 (radio 18)
The code I’m testing.
// twowaytest.ino
// testing 2-way communications with the Fio
int buttonPin = 2; // button with 10k to gnd
int localHbLed = 13; // led to gnd
int remoteHbLed = 12; // led to gnd
int buttonState = 0;
int lastState = 0;
const int terminatingChar = 13; //Terminate lines with CR
void setup(){
  pinMode(localHbLed,OUTPUT);
  pinMode(remoteHbLed,OUTPUT);
  pinMode(buttonPin, INPUT);
  Serial.begin(57600);
  Serial.print(255);
  delay(2000);
  analogReference(EXTERNAL);
  blink(3); // show we're on...
void loop(){
  buttonState = digitalRead(buttonPin);
  if (lastState != buttonState) {
    if (buttonState == HIGH) {
      // turn LED on:
      digitalWrite(localHbLed, HIGH);
      sendDataToOther("pulseUp");
      lastState = HIGH;
    else {
      // turn LED off:
      digitalWrite(localHbLed, LOW);
      sendDataToOther("pulseDn");
      lastState = LOW;
  getDataFromOther();
  delay(20);                          //  take a break
void sendDataToOther(String pulseVal){
  // send info to the other xbee
  if (pulseVal == "pulseUp"){
    Serial.print("pulseUp\r");
  else {
    Serial.print("pulseDn\r");
void getDataFromOther() {
  char* theOtherPulse = serialReader();
  // Serial.print("Other is: ");
  // Serial.println(theOtherPulse);
  // if (theOtherPulse == theOtherTest[0]){
  if (strstr(theOtherPulse, "PulseUp") != 0) {
    digitalWrite(remoteHbLed,HIGH);
    // Serial.print("recd... HIGH ");
  else {
    digitalWrite(remoteHbLed,LOW);
    // Serial.print("recd... LOW ");
// read serial port
char* serialReader(){
  int makeSerialStringPosition;
  int inByte;
  char serialReadString[50] = "";
  inByte = Serial.read();
  makeSerialStringPosition=0;
  if (inByte > 0 && inByte != terminatingChar) { //If we see data (inByte > 0) and that data isn't a carriage return
    delay(100); //Allow serial data time to collect (I think. All I know is it doesn't work without this.)
    while (inByte != terminatingChar && Serial.available() > 0){ // As long as EOL not found and there's more to read, keep reading
      serialReadString[makeSerialStringPosition] = inByte; // Save the data in a character array
      makeSerialStringPosition++; //Increment position in array
      //if (inByte > 0) Serial.println(inByte); // Debug line that prints the charcodes one per line for everything recieved over serial
      inByte = Serial.read(); // Read next byte
    if (inByte == terminatingChar) //If we terminated properly
      serialReadString[makeSerialStringPosition] = 0; //Null terminate the serialReadString (Overwrites last position char (terminating char) with 0
      // Serial.print("from method: ");
      // Serial.println(serialReadString);
      // if (strcmp(serialReadString, "LEDOn") == 0) digitalWrite(13, HIGH);
      // if (strcmp(serialReadString, "LEDOff") == 0) digitalWrite(13, LOW);
      return serialReadString;
  return "x"; // return this when nothing is recieved...
int stringToInt(String thisString) {
  int i, value, length;
  length = thisString.length();
  char blah[(length+1)];
  for(i=0; i<length; i++) {
    blah[i] = thisString.charAt(i);
  blah[i]=0;
  value = atoi(blah);
  return value;
// blink n times
void blink(int howManyTimes){
  digitalWrite(remoteHbLed, LOW);
  delay(200);
  for (int i=0; i< howManyTimes; i++){
    delay(200);
    digitalWrite(remoteHbLed, HIGH);
    delay(200);
There are at least 2 problems in function serialReader:
  1. You are returning the address of local variable serialReadString. That variable is created on the stack and ceases to exist when the function returns. Declaring it static will fix the problem.
  2. You have a classic buffer overflow bug. if the terminating character is not received within 50 characters, the buffer will overflow. You should not increment variable makeSerialStringPosition beyond 49.
I seem to have it working. Thanks, dc42.
// twowaytest.ino
// XBee settings (use X-TCU)
// XBee 1:
// PAN ID: 1111
// DH: 0
// DL: 12
// MY: 11 (radio 17)
// XBee 2:
// PAN ID: 1111
// DH: 0
// DL: 11
// MY: 12 (radio 18)
int localHbLed = 13; // LED to gnd
int remoteHbLed = 12; // LED to gnd
int index = 0;
int lastState = 0;
const int terminatingChar = 13; // Terminate lines with CR
void setup(){
  Serial.print(255);
  analogReference(EXTERNAL); // set up for 3.3v usage
  delay(2000);
void loop(){
      // turn LED on:
      lastState = HIGH;
    if (buttonState == LOW) {
      // turn LED off:
      lastState = LOW;
  getDataFromOther();
  delay(50);    //  take a break
  else {
  if (strcmp(theOtherPulse, "pulseUp") == 0) {
    Serial.println("recd... HIGH ");
  if (strcmp(theOtherPulse, "pulseDn") == 0) {
    Serial.println("recd... LOW ");
// read serial port
  static char serialReadString[50] = "";
  index=0;
  int inByte = Serial.read();
    delay(50); //Allow serial data time to collect
    while (Serial.available() > 0 && inByte != terminatingChar && index <= 49) {
      serialReadString[index] = inByte; // Save the data in a character array
      index++; // increment position in array
    if (index >= 49){
      return "b"; // return this when the buffer is full...
    // If we terminated properly
    if (inByte == terminatingChar) {
      serialReadString[index] = 0; //Null terminate the serialReadString (Overwrites last position char (terminating char) with 0
  return "n"; // return this when nothing is received...
// convert string to int
  blah[i]=0;
  value = atoi(blah);
  return value;
// blink n times
  delay(200);
    delay(200);
    delay(200);
