FIO hangs when XBee plug on
Hello,
I can't get the FIO working when a XBee is plugged on.
A simple led13 blinking (without anything linked to the serial) will work when there is no XBee and will not work with a XBee.
The issue appeared with different xbees (and they are functionnal).
I noted that without the xbee, the ON led is not lighten (while the device is obviously running). With the xbee, it is lighten.
The configuration is standard and I haven't done the configs to enable wireless programming...
Do anyone has an idea what I'm doing wrong?
Thanks!
Well, after some investigation, I found out that if the arduino is powered with the 3v3 FTDI port, it will boot normally and send messages via the XBee...
Would it be a problem with the FIO 3v3 regulator?
