Microcontroller ATmega328P
Operating Voltage 3.3V
Input Voltage 3.35 -12 V
Input Voltage for Charge 3.7 - 7 V
Digital I/O Pins 14 (of which 6 provide PWM output)
Analog Input Pins 8
DC Current per I/O Pin 40 mA
Flash Memory 32 KB (of which 2 KB used by bootloader)
SRAM 2 KB
EEPROM 1 KB
Clock Speed 8 MHz
but before powering it i want to make sure from where i should power it with 7.4volts that i have from a battery? is from the +/- BATT points ?
NI$HANT:
Based on the schematic, Vbat is attached to the 3v3 regulator. Sounds like that's where you want to attach it.
