I have two xbees wich are sitting on FIO and UNO. I want to send few sensor values from FIO to UNO.
If i use serial monitor on FIO it will print all values just fine like this:
Kaikki anturit loytyi
anturi1: 26.19
anturi2: 26.12
anturi3: 26.25
valo: 466
h
l
anturi1: 26.25
anturi2: 26.06
anturi3: 26.25
valo: 448
h
l
anturi1: 26.25
anturi2: 26.06
anturi3: 26.25
valo: 439
But over the XBEE when monitoring UNO’s :
anturi1: 26.37
anturi2: 26.37
anturi3: 26.50
val
o: 423
h
l
anturi1: 26.44
anturi2: 26.31
anturi3: 26.44
val
o: 445
h
l
Im using Series1 xbee’s so they are just a transparent bridge. Code follows:
RECEIVER
char data;
const int ledpin = 13;
pinMode(ledpin, OUTPUT);
void loop(){
if(Serial.available() > 0){
data = Serial.read();
if(data == 'h'){
digitalWrite(ledpin, HIGH);
Serial.println(data);
else if(data == 'l'){
digitalWrite(ledpin, LOW);
else{
Serial.print(data);
delay(50);
TRANSMITTER
#include <DallasTemperature.h>
#include <OneWire.h>
//#include <LiquidCrystal.h>
//LiquidCrystal lcd(12, 11, 10, 9, 8, 7);
#include <DHT.h>
#define DHTPIN 13
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
// 1-WIRE
// anturin data-jalka
#define ONE_WIRE_BUS 6
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
float temparray[3]; // define array for sensors
int i = 0; // int for anturilkm
int anturilkm;
const int ldrpin = 6;
// lcd.begin(16, 2);
sensors.begin();
pinMode(ldrpin, INPUT);
// dht.begin();
anturilkm = sensors.getDeviceCount();
if (anturilkm = 3)
Serial.println("Kaikki anturit loytyi");
Serial.println("virhe: anturit hukassa!");
delay(3000);
void loop(){
sensors.requestTemperatures();
for(i=0; i < anturilkm; i++)
temparray[i] = sensors.getTempCByIndex(i);
Serial.print("anturi1: ");
Serial.println(temparray[0]);
Serial.print("anturi2: ");
Serial.println(temparray[1]);
Serial.print("anturi3: ");
Serial.println(temparray[2]);
// float anturi1 = sensors.getTempCByIndex(0);
// float anturi2 = sensors.getTempCByIndex(1);
float t = dht.readTemperature();
float h = dht.readHumidity();
Serial.println(t);
Serial.println(h);
int valo = analogRead(ldrpin);
Serial.print("valo: ");
Serial.println(valo);
Serial.println("h");
Serial.println("l");
