hi there does anyone know if an arduino uno can communicate with fire alarm detectors using "Apollo” and “Hochiki protocols it would only be 7 addressable detectors
i know fire alarms use 24v dc and was wondering if i could use optocouplers to take a signal to the arduino and transmit?
thanks alot
this is the only information i can find
TECHNICAL SPECIFICATION
Transmission Type Half duplex, serial asynchronous digital
2 wire, Voltage transmit, Current receive
Data format 8 data bits, 1 start and 1 stop bit
Data rate 1200 bits/second
Operating voltage Digital 0 - 24Vdc
Digital 1 - 32Vdc
Operating current Digital 0 - Loop current + 22mA
Digital 1 - Loop current + 0mA
Error checking Byte - Even parity
Message - 8 bit checksum
Command Types Polling, Control, Interrupt and Group
Polling rate 7.5 seconds per loop
Interrupt response time 1.5 seconds max., 1.0 seconds typ
