Firebase-arduino esp 8266 error
I am new on ardiuno iwant to store data from esp8266 to firebase database
This is the error message displayed:
 Arduino: 1.6.8 (Windows 8.1), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
D:\Arduino\simple\simple.ino: In function 'void setup()':
simple:29: error: no matching function for call to 'FirebaseArduino::setString(const char [4])'
   Firebase.setString("LED");
D:\Arduino\simple\simple.ino:29:27: note: candidate is:
In file included from D:\Arduino\simple\simple.ino:2:0:
C:\Users\Pandey\Documents\Arduino\libraries\firebase-arduino-master\src/FirebaseArduino.h:126:8: note: void FirebaseArduino::setString(const String&, const String&)
   void setString(const String& path, const String& value);
C:\Users\Pandey\Documents\Arduino\libraries\firebase-arduino-master\src/FirebaseArduino.h:126:8: note:   candidate expects 2 arguments, 1 provided
simple:30: error: 'success' was not declared in this scope
   success();
exit status 1
option enabled in File -> Preferences.
MY CODE IS
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
// Set these to run example.
#define FIREBASE_HOST "https://XXXXXX.firebaseio.com/"
#define FIREBASE_AUTH "XXXXXXXXXXXXXXXXXXXXXXXXXXX"
#define WIFI_SSID "XXXXXXX"
#define WIFI_PASSWORD "XXXXXXX"
//const int ledPin = 14;
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("connecting");
    Serial.print(".");
  Serial.print("connected: ");
   Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
  success();
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. Using code tags and other important information is explained in the How to use this forum post. Please read it.
When your code requires a library that’s not included with the Arduino IDE please always post a link (using the chain link icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger(Sketch > Include Library > Manage Libraries) then say so and state the full name of the library.
varun_pandey:
simple:29: error: no matching function for call to ‘FirebaseArduino::setString(const char [4])’
Firebase.setString(“LED”);
When all else fails, read the documentation:
http://firebase-arduino.readthedocs.io/en/latest/#_CPPv2N15FirebaseArduino9setStringERK6StringRK6String
