Firebase client and ESP mail client not working together
Hello everyone please I have a code where am using the firebase client library and the ESP mail client library together and am getting this long error that i can't make nothing out of. For some reason they don't seem to be working when placed in the same code sketch. Note that i have updated the two libraries, deleted the SSLClient Folder from the ESP mail client library and it still did not work instead i get a new error after deleting the SSLClient folder. Someone pls help me solve this error please. I'm working with the Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32 and ESP_Mail_Client library
#include <WiFi.h>
#include <Firebase_ESP_Client.h>
#include <addons/RTDBHelper.h>
#include <addons/TokenHelper.h>
#include <ESP_Mail_Client.h>
//Creating the WiFi config
const char* ssid = "*********";
const char* password ="***********";
//Creating the Email config
#define senderEmail "*********"
#define senderPassword "***********"
#define smtpHost "smtp.gmail.com"
#define smtpPort 465
#define emailSubject "************"
#define recipientEmail "************"
//Database Configuration Details
#define APIKey " "
#define DatabaseUrl " "
#define AppId " "
#define UserEmail " "
#define UserPassword ""
//Firebase Objects
FirebaseAuth Fauth;
FirebaseConfig Fconfig;
FirebaseData Fdata;
FirebaseData stream1;
FirebaseData stream2;
//Email Object
SMTPSession mySmtp;
//Getting the connected user ID
String uid;
//Database Paths
String databasePath;
String btn1Path;
String btn2Path;
String btn3Path;
String locationPath;
String redPath;
String greenPath;
String bluePath;
String buttonsListenerPath;
String outputsListenerPath;
//Physical Components
#define btn1 26
#define btn2 32
#define btn3 2
#define blue 12
#define green 14
#define red 13
//Timing Variables
unsigned long sendDataCurrTime;
unsigned long sendDataPrevTime;
int timerDelay = 5000;
void initWiFi(){
  Serial.println("Entered the wifi initialization!");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED){
    Serial.print('.');
  Serial.println("Connected....");
//Writing Data To Our Database
void sendData(String path, int value){
  if(Firebase.RTDB.setInt(&Fdata, path.c_str(), value)){
    Serial.println("Writing data was successful!");
    Serial.println(Fdata.dataPath());
  else {
    Serial.println("Failed!" + String(Fdata.errorReason()));
//Reading from the database
int getData(String path){
  if(Firebase.RTDB.getInt(&Fdata, path.c_str())){
    int state = Fdata.intData();
    Serial.println(F("Retrieved Data Successful"));
    return state;
  else{
    Serial.println(F("Failed to read data!"));
//Creating the stream call back function
void buttonStreamCallBack(FirebaseStream streammedData){
  if(streammedData.dataPath() == "/btn1"){
    digitalWrite(red, streammedData.intData());
  if(streammedData.dataPath() == "/btn2"){
    digitalWrite(blue, streammedData.intData());
  if(streammedData.dataPath() == "/btn3"){
    digitalWrite(green, streammedData.intData());
  if(streammedData.dataPath().length()==0){
    Serial.println("No new data from the buttons");
void streamTimeOut1(bool timeout){
  if(timeout){
    Serial.println("Stream has timed out!..........");
  if(!stream1.httpConnected()){
    Serial.println("Stream disconnected! " + String(stream1.httpCode()));
//EMAIL RELATED FUNCTIONS
void smtpCallback(SMTP_Status status);
  pinMode(red, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(blue, OUTPUT);
  pinMode(btn1, INPUT_PULLDOWN);
  pinMode(btn2, INPUT_PULLDOWN);
  pinMode(btn3, INPUT_PULLDOWN);
  initWiFi();
  /*ALL EMAIL SETTINGS AND CONFIGS */
  mySmtp.debug(1);
  mySmtp.callback(smtpCallback);
  /*Configuring The Email Session*/
  ESP_Mail_Session mySession; //Creating the email session object instance called mySession
  mySession.server.host_name = smtpHost;
  mySession.server.port = smtpPort;
  mySession.login.email = senderEmail;
  mySession.login.password = senderPassword;
  mySession.login.user_domain ="gmail.com";//Optional configuration
  /* Configuring The Message To Be Sent*/
  SMTP_Message message; //Create the smtp message class called message
  message.sender.name = "ESP32";
  message.sender.email = senderEmail;
  message.subject = emailSubject;
  message.addRecipient("FDC", recipientEmail);
  //Setting The Actual Message Content
  String textMsg = "Hello From FDC EMRRS ESP";
  message.text.content = textMsg.c_str();
  message.text.charSet = "us-ascii";
  message.text.transfer_encoding = Content_Transfer_Encoding::enc_7bit;
  message.priority = esp_mail_smtp_priority::esp_mail_smtp_priority_low;
  message.response.notify = esp_mail_smtp_notify_success | esp_mail_smtp_notify_failure | esp_mail_smtp_notify_delay;
  if(!mySmtp.connect(&mySession)){
    return;
  if(!MailClient.sendMail(&mySmtp, &message)){
    Serial.println("Error sending email " + mySmtp.errorReason());
  //Configuring My Database To Link To My Firebase App
  Fconfig.api_key = APIKey;
  Fconfig.database_url = DatabaseUrl;
  //Authenticating The ESP to have Access
  Fauth.user.email = UserEmail;
  Fauth.user.password = UserPassword;
  //Required settings for data transmission and reconnection
  Firebase.reconnectWiFi(true);
  Fdata.setResponseSize(4096);
  Fconfig.max_token_generation_retry = 5;
  //Starting our firebase server
  Firebase.begin(&Fconfig, &Fauth);
  //Getting The User ID
  Serial.print("Getting UID");
  while(Fauth.token.uid == ""){
    Serial.print('.');
  uid = Fauth.token.uid.c_str();
  Serial.println("User: " + String(uid));
  //Setting Up The Database Paths
  databasePath = "UsersData";
  btn1Path = databasePath + "/buttons/btn1";
  btn2Path = databasePath + "/buttons/btn2";
  btn3Path = databasePath + "/buttons/btn3";
  redPath = databasePath + "/outputs/red";
  bluePath = databasePath + "/outputs/blue";
  greenPath = databasePath + "/outputs/green";
  locationPath = databasePath + "/location";
  buttonsListenerPath = databasePath + "/buttons";
  if(!Firebase.RTDB.beginStream(&stream1, buttonsListenerPath.c_str())){
    Serial.println("Error listening to this path:" + String(stream1.errorReason().c_str()));
  if(!Firebase.RTDB.beginStream(&stream2, outputsListenerPath.c_str())){
    Serial.println("Error listening to this path:" + String(stream2.errorReason().c_str()));
  Firebase.RTDB.setStreamCallback(&stream1, buttonStreamCallBack, streamTimeOut1);
  Serial.println("..........................");
  sendDataCurrTime = millis();
  if(Firebase.ready() && (sendDataCurrTime - sendDataPrevTime)>=timerDelay){
    sendDataPrevTime = sendDataCurrTime;
    sendData(btn1Path, digitalRead(btn1));
    sendData(btn2Path, digitalRead(btn2));
    sendData(btn3Path,  digitalRead(btn3));
  }else{
    Serial.println("Firebase Database Is Not Ready!");
  delay(2000);
//Smtp Callback Function
void smtpCallback(SMTP_Status status){
  Serial.println(status.info());
  if(status.success()){
    Serial.println("******Email Success Status*******");
    ESP_MAIL_PRINTF("Message sent success: %d\n",status.completedCount());
    ESP_MAIL_PRINTF("Message sent failed: %d\n",status.failedCount());
    Serial.println("\n");
    struct tm dt;
    for (size_t i = 0; i<mySmtp.sendingResult.size(); i++){
      SMTP_Result result = mySmtp.sendingResult.getItem(i);
      time_t ts = (time_t)result.timestamp;
      localtime_r(&ts, &dt);
      ESP_MAIL_PRINTF("Message No: %d\n", i + 1);
      ESP_MAIL_PRINTF("Status: %s\n", result.completed ? "success" : "failed");
      ESP_MAIL_PRINTF("Date/Time: %d/%d/%d %d:%d:%d\n", dt.tm_year + 1900, dt.tm_mon + 1, dt.tm_mday, dt.tm_hour, dt.tm_min, dt.tm_sec);
      ESP_MAIL_PRINTF("Recipient: %s\n", result.recipients.c_str());
      ESP_MAIL_PRINTF("Subject: %s\n", result.subject.c_str());
    Serial.println("----------------\n");
This is the error that am getting
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_moddiv.c.o): in function `br_i15_moddiv':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_moddiv.c:250: multiple definition of `br_i15_moddiv'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_moddiv.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_moddiv.c:250: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_modpow.c.o): in function `br_i15_modpow':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_modpow.c:36: multiple definition of `br_i15_modpow'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_modpow.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_modpow.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_modpow2.c.o): in function `br_i15_modpow_opt':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_modpow2.c:36: multiple definition of `br_i15_modpow_opt'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_modpow2.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_modpow2.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_montmul.c.o): in function `br_i15_montymul':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_montmul.c:35: multiple definition of `br_i15_montymul'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_montmul.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_montmul.c:35: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_mulacc.c.o): in function `br_i15_mulacc':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_mulacc.c:34: multiple definition of `br_i15_mulacc'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_mulacc.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_mulacc.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_muladd.c.o): in function `br_i15_muladd_small':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_muladd.c:60: multiple definition of `br_i15_muladd_small'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_muladd.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_muladd.c:60: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_ninv15.c.o): in function `br_i15_ninv15':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_ninv15.c:34: multiple definition of `br_i15_ninv15'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_ninv15.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_ninv15.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_reduce.c.o): in function `br_i15_reduce':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_reduce.c:34: multiple definition of `br_i15_reduce'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_reduce.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_reduce.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_rshift.c.o): in function `br_i15_rshift':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_rshift.c:34: multiple definition of `br_i15_rshift'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_rshift.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_rshift.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_sub.c.o): in function `br_i15_sub':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_sub.c:34: multiple definition of `br_i15_sub'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_sub.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_sub.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i15_tmont.c.o): in function `br_i15_to_monty':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i15_tmont.c:34: multiple definition of `br_i15_to_monty'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i15_tmont.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i15_tmont.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_add.c.o): in function `br_i31_add':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_add.c:34: multiple definition of `br_i31_add'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_add.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_add.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_bitlen.c.o): in function `br_i31_bit_length':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_bitlen.c:34: multiple definition of `br_i31_bit_length'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_bitlen.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_bitlen.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_decmod.c.o): in function `br_i31_decode_mod':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_decmod.c:34: multiple definition of `br_i31_decode_mod'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_decmod.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_decmod.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_decode.c.o): in function `br_i31_decode':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_decode.c:34: multiple definition of `br_i31_decode'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_decode.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_decode.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_decred.c.o): in function `br_i31_decode_reduce':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_decred.c:35: multiple definition of `br_i31_decode_reduce'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_decred.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_decred.c:35: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_encode.c.o): in function `br_i31_encode':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_encode.c:34: multiple definition of `br_i31_encode'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_encode.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_encode.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_fmont.c.o): in function `br_i31_from_monty':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_fmont.c:34: multiple definition of `br_i31_from_monty'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_fmont.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_fmont.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_iszero.c.o): in function `br_i31_iszero':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_iszero.c:34: multiple definition of `br_i31_iszero'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_iszero.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_iszero.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_moddiv.c.o): in function `br_i31_moddiv':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_moddiv.c:263: multiple definition of `br_i31_moddiv'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_moddiv.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_moddiv.c:263: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_modpow.c.o): in function `br_i31_modpow':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_modpow.c:36: multiple definition of `br_i31_modpow'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_modpow.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_modpow.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_modpow2.c.o): in function `br_i31_modpow_opt':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_modpow2.c:36: multiple definition of `br_i31_modpow_opt'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_modpow2.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_modpow2.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_montmul.c.o): in function `br_i31_montymul':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_montmul.c:35: multiple definition of `br_i31_montymul'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_montmul.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_montmul.c:35: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_mulacc.c.o): in function `br_i31_mulacc':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_mulacc.c:34: multiple definition of `br_i31_mulacc'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_mulacc.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_mulacc.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_muladd.c.o): in function `br_i31_muladd_small':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_muladd.c:34: multiple definition of `br_i31_muladd_small'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_muladd.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_muladd.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_ninv31.c.o): in function `br_i31_ninv31':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_ninv31.c:34: multiple definition of `br_i31_ninv31'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_ninv31.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_ninv31.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_reduce.c.o): in function `br_i31_reduce':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_reduce.c:34: multiple definition of `br_i31_reduce'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_reduce.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_reduce.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_rshift.c.o): in function `br_i31_rshift':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_rshift.c:34: multiple definition of `br_i31_rshift'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_rshift.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_rshift.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_sub.c.o): in function `br_i31_sub':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_sub.c:34: multiple definition of `br_i31_sub'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_sub.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_sub.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i31_tmont.c.o): in function `br_i31_to_monty':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i31_tmont.c:34: multiple definition of `br_i31_to_monty'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i31_tmont.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i31_tmont.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_add.c.o): in function `br_i32_add':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_add.c:34: multiple definition of `br_i32_add'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_add.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_add.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_bitlen.c.o): in function `br_i32_bit_length':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_bitlen.c:34: multiple definition of `br_i32_bit_length'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_bitlen.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_bitlen.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_decmod.c.o): in function `br_i32_decode_mod':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_decmod.c:34: multiple definition of `br_i32_decode_mod'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_decmod.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_decmod.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_decode.c.o): in function `br_i32_decode':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_decode.c:34: multiple definition of `br_i32_decode'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_decode.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_decode.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_decred.c.o): in function `br_i32_decode_reduce':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_decred.c:35: multiple definition of `br_i32_decode_reduce'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_decred.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_decred.c:35: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_div32.c.o): in function `br_divrem':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_div32.c:34: multiple definition of `br_divrem'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_div32.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_div32.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_encode.c.o): in function `br_i32_encode':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_encode.c:34: multiple definition of `br_i32_encode'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_encode.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_encode.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_fmont.c.o): in function `br_i32_from_monty':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_fmont.c:34: multiple definition of `br_i32_from_monty'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_fmont.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_fmont.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_iszero.c.o): in function `br_i32_iszero':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_iszero.c:34: multiple definition of `br_i32_iszero'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_iszero.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_iszero.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_modpow.c.o): in function `br_i32_modpow':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_modpow.c:36: multiple definition of `br_i32_modpow'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_modpow.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_modpow.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_montmul.c.o): in function `br_i32_montymul':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_montmul.c:35: multiple definition of `br_i32_montymul'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_montmul.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_montmul.c:35: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_mulacc.c.o): in function `br_i32_mulacc':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_mulacc.c:34: multiple definition of `br_i32_mulacc'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_mulacc.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_mulacc.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_muladd.c.o): in function `br_i32_muladd_small':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_muladd.c:34: multiple definition of `br_i32_muladd_small'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_muladd.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_muladd.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_ninv32.c.o): in function `br_i32_ninv32':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_ninv32.c:34: multiple definition of `br_i32_ninv32'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_ninv32.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_ninv32.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_reduce.c.o): in function `br_i32_reduce':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_reduce.c:34: multiple definition of `br_i32_reduce'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_reduce.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_reduce.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_sub.c.o): in function `br_i32_sub':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_sub.c:34: multiple definition of `br_i32_sub'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_sub.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_sub.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i32_tmont.c.o): in function `br_i32_to_monty':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i32_tmont.c:34: multiple definition of `br_i32_to_monty'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i32_tmont.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i32_tmont.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i62_modpow2.c.o): in function `br_i62_modpow_opt':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i62_modpow2.c:472: multiple definition of `br_i62_modpow_opt'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i62_modpow2.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i62_modpow2.c:472: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(i62_modpow2.c.o): in function `br_i62_modpow_opt_as_i31':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/i62_modpow2.c:489: multiple definition of `br_i62_modpow_opt_as_i31'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(i62_modpow2.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/i62_modpow2.c:489: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5.c.o): in function `br_md5_set_state':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5.c:193: multiple definition of `br_md5_set_state'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5.c:193: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5.c:199: multiple definition of `br_md5_vtable'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5.c:199: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5.c:39: multiple definition of `br_md5_IV'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5.c:39: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5.c.o): in function `br_md5_init':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5.c:124: multiple definition of `br_md5_init'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5.c:124: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5.c.o): in function `br_md5_state':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5.c:185: multiple definition of `br_md5_state'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5.c:185: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5.c.o): in function `br_md5_round':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5.c:74: multiple definition of `br_md5_round'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5.c:74: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5.c.o): in function `br_md5_update':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5.c:133: multiple definition of `br_md5_update'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5.c:133: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5.c.o): in function `br_md5_out':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5.c:161: multiple definition of `br_md5_out'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5.c:161: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5sha1.c.o):c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5sha1.c:130: multiple definition of `br_md5sha1_vtable'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5sha1.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5sha1.c:130: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5sha1.c.o): in function `br_md5sha1_init':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5sha1.c:34: multiple definition of `br_md5sha1_init'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5sha1.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5sha1.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5sha1.c.o): in function `br_md5sha1_update':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5sha1.c:44: multiple definition of `br_md5sha1_update'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5sha1.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5sha1.c:44: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5sha1.c.o): in function `br_md5sha1_state':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5sha1.c:108: multiple definition of `br_md5sha1_state'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5sha1.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5sha1.c:108: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5sha1.c.o): in function `br_md5sha1_set_state':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5sha1.c:120: multiple definition of `br_md5sha1_set_state'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5sha1.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5sha1.c:120: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(md5sha1.c.o): in function `br_md5sha1_out':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/md5sha1.c:73: multiple definition of `br_md5sha1_out'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(md5sha1.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/md5sha1.c:73: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(mgf1.c.o): in function `br_mgf1_xor':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/mgf1.c:35: multiple definition of `br_mgf1_xor'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(mgf1.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/mgf1.c:35: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(multihash.c.o): in function `br_multihash_zero':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/multihash.c:79: multiple definition of `br_multihash_zero'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(multihash.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/multihash.c:79: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(multihash.c.o): in function `br_multihash_init':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/multihash.c:90: multiple definition of `br_multihash_init'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(multihash.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/multihash.c:90: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(multihash.c.o): in function `br_multihash_update':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/multihash.c:111: multiple definition of `br_multihash_update'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(multihash.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/multihash.c:111: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(multihash.c.o): in function `br_multihash_out':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/multihash.c:156: multiple definition of `br_multihash_out'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(multihash.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/multihash.c:156: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pemdec.c.o): in function `br_pem_decoder_event':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pemdec.c:106: multiple definition of `br_pem_decoder_event'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pemdec.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pemdec.c:106: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pemdec.c.o): in function `br_pem_decoder_init_main':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pemdec.c:222: multiple definition of `br_pem_decoder_init_main'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pemdec.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pemdec.c:222: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pemdec.c.o): in function `br_pem_decoder_run':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pemdec.c:228: multiple definition of `br_pem_decoder_run'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pemdec.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pemdec.c:228: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pemdec.c.o): in function `br_pem_decoder_init':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pemdec.c:81: multiple definition of `br_pem_decoder_init'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pemdec.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pemdec.c:81: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pemdec.c.o): in function `br_pem_decoder_push':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pemdec.c:93: multiple definition of `br_pem_decoder_push'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pemdec.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pemdec.c:93: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pemenc.c.o): in function `br_pem_encode':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pemenc.c:71: multiple definition of `br_pem_encode'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pemenc.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pemenc.c:71: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pkey_decoder.c.o): in function `br_pkey_decoder_init_main':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pkey_decoder.c:303: multiple definition of `br_pkey_decoder_init_main'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pkey_decoder.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pkey_decoder.c:303: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pkey_decoder.c.o): in function `br_pkey_decoder_run':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pkey_decoder.c:309: multiple definition of `br_pkey_decoder_run'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pkey_decoder.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pkey_decoder.c:309: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pkey_decoder.c.o): in function `br_pkey_decoder_init':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pkey_decoder.c:109: multiple definition of `br_pkey_decoder_init'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pkey_decoder.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pkey_decoder.c:109: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(pkey_decoder.c.o): in function `br_pkey_decoder_push':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/pkey_decoder.c:121: multiple definition of `br_pkey_decoder_push'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(pkey_decoder.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/pkey_decoder.c:121: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(poly1305_ctmul.c.o): in function `br_poly1305_ctmul_run':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/poly1305_ctmul.c:155: multiple definition of `br_poly1305_ctmul_run'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(poly1305_ctmul.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/poly1305_ctmul.c:155: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(poly1305_ctmul32.c.o): in function `br_poly1305_ctmul32_run':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/poly1305_ctmul32.c:173: multiple definition of `br_poly1305_ctmul32_run'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(poly1305_ctmul32.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/poly1305_ctmul32.c:173: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(poly1305_ctmulq.c.o): in function `br_poly1305_ctmulq_get':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/poly1305_ctmulq.c:475: multiple definition of `br_poly1305_ctmulq_get'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(poly1305_ctmulq.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/poly1305_ctmulq.c:475: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(poly1305_i15.c.o): in function `br_poly1305_i15_run':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/poly1305_i15.c:136: multiple definition of `br_poly1305_i15_run'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(poly1305_i15.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/poly1305_i15.c:136: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(prf.c.o): in function `br_tls_phash':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/prf.c:37: multiple definition of `br_tls_phash'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(prf.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/prf.c:37: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(prf_md5sha1.c.o): in function `br_tls10_prf':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/prf_md5sha1.c:36: multiple definition of `br_tls10_prf'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(prf_md5sha1.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/prf_md5sha1.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(prf_sha256.c.o): in function `br_tls12_sha256_prf':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/prf_sha256.c:36: multiple definition of `br_tls12_sha256_prf'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(prf_sha256.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/prf_sha256.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(prf_sha384.c.o): in function `br_tls12_sha384_prf':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/prf_sha384.c:36: multiple definition of `br_tls12_sha384_prf'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(prf_sha384.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/prf_sha384.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_keygen.c.o): in function `br_rsa_keygen_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_keygen.c:34: multiple definition of `br_rsa_keygen_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_keygen.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_keygen.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_modulus.c.o): in function `br_rsa_compute_modulus_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_modulus.c:34: multiple definition of `br_rsa_compute_modulus_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_modulus.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_modulus.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_oaep_decrypt.c.o): in function `br_rsa_oaep_decrypt_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_oaep_decrypt.c:34: multiple definition of `br_rsa_oaep_decrypt_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_oaep_decrypt.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_oaep_decrypt.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_oaep_encrypt.c.o): in function `br_rsa_oaep_encrypt_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_oaep_encrypt.c:34: multiple definition of `br_rsa_oaep_encrypt_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_oaep_encrypt.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_oaep_encrypt.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_pkcs1_sign.c.o): in function `br_rsa_pkcs1_sign_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_pkcs1_sign.c:34: multiple definition of `br_rsa_pkcs1_sign_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_pkcs1_sign.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_pkcs1_sign.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_pkcs1_vrfy.c.o): in function `br_rsa_pkcs1_vrfy_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_pkcs1_vrfy.c:34: multiple definition of `br_rsa_pkcs1_vrfy_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_pkcs1_vrfy.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_pkcs1_vrfy.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_priv.c.o): in function `br_rsa_private_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_priv.c:34: multiple definition of `br_rsa_private_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_priv.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_priv.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_privexp.c.o): in function `br_rsa_compute_privexp_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_privexp.c:34: multiple definition of `br_rsa_compute_privexp_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_privexp.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_privexp.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_pss_sign.c.o): in function `br_rsa_pss_sign_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_pss_sign.c:34: multiple definition of `br_rsa_pss_sign_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_pss_sign.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_pss_sign.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_pss_vrfy.c.o): in function `br_rsa_pss_vrfy_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_pss_vrfy.c:34: multiple definition of `br_rsa_pss_vrfy_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_pss_vrfy.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_pss_vrfy.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_pub.c.o): in function `br_rsa_public_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_pub.c:34: multiple definition of `br_rsa_public_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_pub.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_pub.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_default_pubexp.c.o): in function `br_rsa_compute_pubexp_get_default':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_default_pubexp.c:34: multiple definition of `br_rsa_compute_pubexp_get_default'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_default_pubexp.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_default_pubexp.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_keygen.c.o): in function `br_rsa_i15_keygen':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_keygen.c:445: multiple definition of `br_rsa_i15_keygen'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_keygen.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_keygen.c:445: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_modulus.c.o): in function `br_rsa_i15_compute_modulus':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_modulus.c:34: multiple definition of `br_rsa_i15_compute_modulus'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_modulus.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_modulus.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_oaep_decrypt.c.o): in function `br_rsa_i15_oaep_decrypt':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_oaep_decrypt.c:37: multiple definition of `br_rsa_i15_oaep_decrypt'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_oaep_decrypt.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_oaep_decrypt.c:37: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_oaep_encrypt.c.o): in function `br_rsa_i15_oaep_encrypt':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_oaep_encrypt.c:39: multiple definition of `br_rsa_i15_oaep_encrypt'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_oaep_encrypt.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_oaep_encrypt.c:39: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_pkcs1_sign.c.o): in function `br_rsa_i15_pkcs1_sign':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_pkcs1_sign.c:36: multiple definition of `br_rsa_i15_pkcs1_sign'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_pkcs1_sign.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_pkcs1_sign.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_pkcs1_vrfy.c.o): in function `br_rsa_i15_pkcs1_vrfy':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_pkcs1_vrfy.c:36: multiple definition of `br_rsa_i15_pkcs1_vrfy'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_pkcs1_vrfy.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_pkcs1_vrfy.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_priv.c.o): in function `br_rsa_i15_private':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_priv.c:37: multiple definition of `br_rsa_i15_private'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_priv.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_priv.c:37: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_privexp.c.o): in function `br_rsa_i15_compute_privexp':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_privexp.c:35: multiple definition of `br_rsa_i15_compute_privexp'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_privexp.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_privexp.c:35: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_pss_sign.c.o): in function `br_rsa_i15_pss_sign':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_pss_sign.c:37: multiple definition of `br_rsa_i15_pss_sign'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_pss_sign.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_pss_sign.c:37: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_pss_vrfy.c.o): in function `br_rsa_i15_pss_vrfy':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_pss_vrfy.c:36: multiple definition of `br_rsa_i15_pss_vrfy'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_pss_vrfy.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_pss_vrfy.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_pub.c.o): in function `br_rsa_i15_public':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_pub.c:41: multiple definition of `br_rsa_i15_public'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_pub.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_pub.c:41: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i15_pubexp.c.o): in function `br_rsa_i15_compute_pubexp':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i15_pubexp.c:146: multiple definition of `br_rsa_i15_compute_pubexp'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i15_pubexp.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i15_pubexp.c:146: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i31_keygen.c.o): in function `br_rsa_i31_keygen':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i31_keygen.c:37: multiple definition of `br_rsa_i31_keygen'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i31_keygen.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i31_keygen.c:37: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i31_keygen_inner.c.o): in function `br_rsa_i31_keygen_inner':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i31_keygen_inner.c:466: multiple definition of `br_rsa_i31_keygen_inner'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i31_keygen_inner.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i31_keygen_inner.c:466: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i31_modulus.c.o): in function `br_rsa_i31_compute_modulus':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i31_modulus.c:34: multiple definition of `br_rsa_i31_compute_modulus'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i31_modulus.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i31_modulus.c:34: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i31_oaep_decrypt.c.o): in function `br_rsa_i31_oaep_decrypt':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i31_oaep_decrypt.c:36: multiple definition of `br_rsa_i31_oaep_decrypt'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i31_oaep_decrypt.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i31_oaep_decrypt.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i31_oaep_encrypt.c.o): in function `br_rsa_i31_oaep_encrypt':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i31_oaep_encrypt.c:39: multiple definition of `br_rsa_i31_oaep_encrypt'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i31_oaep_encrypt.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i31_oaep_encrypt.c:39: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i31_pkcs1_sign.c.o): in function `br_rsa_i31_pkcs1_sign':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i31_pkcs1_sign.c:36: multiple definition of `br_rsa_i31_pkcs1_sign'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\bssl\objs.a(rsa_i31_pkcs1_sign.c.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\bssl/rsa_i31_pkcs1_sign.c:36: first defined here
c:/users/user/appdata/local/arduino15/packages/esp32/tools/esp-x32/2302/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\ESP_Mail_Client\client\SSLClient\bssl\objs.a(rsa_i31_pkcs1_vrfy.c.o): in function `br_rsa_i31_pkcs1_vrfy':
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\bssl/rsa_i31_pkcs1_vrfy.c:36: multiple definition of `br_rsa_i31_pkcs1_vrfy'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9
c:\Users\USER\Documents\Arduino\libraries\ESP_Mail_Client\src\client\SSLClient\client/BSSL_TCP_Client.cpp:147: multiple definition of `BSSL_TCP_Client::available()'; C:\Users\USER\AppData\Local\Temp\arduino\sketches\C2D9542F252F3469F0D72C9ECA6DBA62\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\client\SSLClient\client\objs.a(BSSL_TCP_Client.cpp.o):c:\Users\USER\Documents\Arduino\libraries\Firebase_Arduino_Client_Library_for_ESP8266_and_ESP32\src\client\SSLClient\client/BSSL_TCP_Client.cpp:297: first defined here
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "SD.h"
  Used: C:\Users\USER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.5\libraries\SD
  Not used: C:\Users\USER\AppData\Local\Arduino15\libraries\SD
exit status 1
Compilation error: exit status 1
Post all the code in code tags, and the verbose complete error log in code tags.
Hello, i have edited the post to include the complete code and the error am getting.
The errors aren't in code tags, but don't worry, You have an error in the first couple lines, fix that and try again.
@fdcdev2024 were you able to solve the problem?
I have having this problem too. The Esp_mail_client library is conflicting with Firebase_esp32 library.
If i comment out the Esp_mail_client , everything works fine. Also, testing individual codes works fine too but integrating it together is the problem.
