Firebase Cloud function not working accordingly with IOT
my firebase cloud functions are as follows oem purifier
exports.sendSMSNotfication = functions.database.ref('issue/{id}').onCreate(async (snapshot, context) => {
    const val = snapshot.val();
    var lampnumb=val.Issue.substring(0,7);
    var desc=val.Issue.substring(10);
    admin.database().ref('lamps/'+lampnumb).on('value', function (snapshot) {
        var data = snapshot.val();
           own=data.Owner;
    return admin.database().ref('owners/'+own).on('value', function (snapshot) {
            client.messages
                .create({
                    body: '\nAlert\nSmartLampPole ' + lampnumb + ' is facing an issue\nReported as ' + desc + '.',
                    to: data.Contact
                .then(message => console.log(message.sid));
exports.addHistory = functions.database.ref('issue/{id}').onCreate(async (snapshot, context) => {
    var today = new Date();
var datetime = today.toLocaleString('en-GB', {
  timeZone: 'Asia/Calcutta'});
    var own="";
               own=data.Owner;
                return admin.database().ref('history').push().set({
                    Lamp: lampnumb,
                    Reported: datetime,
                    Completed: "",
                    Status: "Pending",
                    AssignedTo: "",
                    Issue: desc,
                    Owner: own
exports.addKeyofHistory = functions.database.ref('history/{id}').onCreate(async (snapshot, context) => {
    const id = snapshot.key;
     admin.database().ref('issue').child(val.Lamp).update({
        HistoryId: id,
        Status: "Pending",
        LampId: val.Lamp,
        Description: val.Issue,
        Owner: val.Owner
    return admin.database().ref('issue/'+val.Lamp+'/Issue').remove();
So here happens when the Arduino code creates an issue it should trigger the function and create a history rec and the issue data should be updated . But when the IOT device is connected this continuously change the history ID
I can not find the reason behind it.
The Arduino code is like this
static bool creported=false;
static bool breported=false;
void loop(){
      Serial.print(breported);
     DHT.read11(dht_apin);
    Serial.print("Current humidity = ");
    Serial.print(DHT.humidity);
    Firebase.setFloat("lamps/lamp001/Humidity",DHT.humidity);
    Serial.print("%  ");
    Serial.print("temperature = ");
    Serial.print(DHT.temperature);
    Firebase.setFloat("lamps/lamp001/Temperature",DHT.temperature);
    Serial.println("C  ");
    delay(5000);
    int temp = digitalRead(ldr1);
    Serial.print("LDR 1 :");
    Serial.println(temp);
    Firebase.setFloat("lamps/lamp001/LDR1",temp);
    if(temp == HIGH)
      /**float avg = 0;
           for(int i=0; i<1000; i++)
               avg = avg + (.0264 * analogRead(crentSen) -13.51)/1000;
               delay(1);
       Serial.print("Current: ");
       Serial.println(avg);
       Firebase.setFloat("lamps/lamp001/Current",avg);
       digitalWrite(relay,LOW);
       delay(5000);
       int volat = digitalRead(voltSen);
       int voltage = volat;
       Serial.print("Voltage: ");
       Serial.println(voltage);
       Firebase.setFloat("lamps/lamp001/Voltage",voltage);
       if (voltage == 1)
             int temp1 = digitalRead(ldr2);
             Serial.print("LDR 2 :");
             Serial.println(temp1);
             creported=false;
             Firebase.setFloat("lamps/lamp001/LDR2",temp1);
              if(temp1 == LOW)
                 Serial.println("Light is working");
                 breported=false;
                 Serial.print(breported +" Bulb\n");
                 Serial.println("BULB IS BURNT");
                 String msg2 ="lamp001";
                 String msg1 ="BULB IS BURNT";
                 if(breported==false)
                   Firebase.setString("issue/lamp001/Issue",msg2+" - "+msg1);
                   breported=true;
          Serial.println("CURRENT NOT PASSING");
          String msg4 ="lamp001";
          String msg3 ="CURRENT NOT PASSING";
            if(creported==false){
               Firebase.setString("issue/lamp001/Issue",msg4+" - "+msg3);
               creported=true;
               Serial.print(creported +" Current\n");
    digitalWrite(relay,HIGH);
  timeClient.update();
  unsigned long epochTime = timeClient.getEpochTime();
  String formattedTime = timeClient.getFormattedTime();
  int currentHour = timeClient.getHours();
  int currentMinute = timeClient.getMinutes();
  int currentSecond = timeClient.getSeconds();
  String weekDay = weekDays[timeClient.getDay()];
  struct tm *ptm = gmtime ((time_t *)&epochTime);
  int monthDay = ptm->tm_mday;
  int currentMonth = ptm->tm_mon+1;
  String currentMonthName = months[currentMonth-1];
  int currentYear = ptm->tm_year+1900;
  String currentDate = String(currentYear) + "-" + String(currentMonth) + "-" + String(monthDay);
  String dateFormat = "GMT+0530 (India Standard Time)";
  Serial.println(weekDay + " " + currentMonthName + " " + monthDay + " " + currentYear + " " + formattedTime + " " + dateFormat);
  String d;
  if(monthDay<10){
    d="0"+(String)monthDay;
  else{
    d=(String)monthDay;
  String TimeZ = weekDay + " " + currentMonthName + " " + d+ " " + (String)currentYear + " " + formattedTime + " " + dateFormat;
  Serial.println(TimeZ);
  Firebase.setString("lamps/lamp001/Time",TimeZ);
  Serial.println("");
  delay(2000);
Note: I have also rise my question already on stackoverflow but did not get my ans so I'm putting me same question here.
