Firebase doesn't receive any updates !
i have a problem on my code that send data from ESP8266 board to firebase
i write a simple code that send a value of a variable to the firebase and increment it and then send it again and so on..
the problem is that the code doesn't send any values to the firebase but the value keeps to be incremented ?
where is the problem ? is that in my code? or in the way of creating the firebase ?
#include <ESP8266WiFi.h>
#include <SoftwareSerial.h>
#include <FirebaseArduino.h>
#define FIREBASE_HOST "lastjune23-23d47-default-rtdb.firebaseio.com"
#define FIREBASE_AUTH "AIzaSyAuKs9XowDTZhn4kqmt8O4xaZSEp1FXSRU"
#define WIFI_SSID "aaa"
#define WIFI_PASS "qwerty123"
float x =0.0;
  WiFi.disconnect();
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  Serial.println("Connecting...");
  while (WiFi.status() != WL_CONNECTED)
    delay(50);
    Serial.print('.');
  Serial.println("");
  Serial.print("Connected, Local IP is: ");
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
  if (Firebase.failed())
    Serial.println("Fisebase log sending failed");
    Serial.println(Firebase.error());
    return;
  Serial.print("x: ");
  Serial.print(x);
  Serial.print("\n");
  Firebase.setFloat("TEST/x_float",x++);
I moved your topic to an appropriate forum category @khali1499.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
sorry about that! , and thanks for contributing!
Hi, I have the same problem! did you find the solution? If so can you tell me how to fix it please?
