I posted this question on github GitHub · Where software is built , but I thought it would be wise to ask it here also... Any insight is appreciated.
I feel very close to getting the ESP32 - Firebase firmware to work reliably. It seems to run fine, but will periodically have the following:
"response payload read timed out due to network issue or too large data size" The only data exchanged with the RTDB is a single integer.
Based on the lack of serial output, the WIFI connection appears to be connected and not the cause of the problem.
The best solution I found is a restart...
I don't understand all the options available. Is there something I'm missing to keep the connection to the database?
Arduino 1.8.19
Adafruit (PID 3591) HUZZAH32 – ESP32 Feather Board
2022-08-23 18:56:47 --> ets Jul 29 2019 12:21:46
2022-08-23 18:56:47 --> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
2022-08-23 18:56:47 --> configsip: 0, SPIWP:0xee
2022-08-23 18:56:47 --> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
2022-08-23 18:56:47 --> mode:DIO, clock div:1
2022-08-23 18:56:47 --> load:0x3fff0030,len:1184
2022-08-23 18:56:47 --> load:0x40078000,len:12812
2022-08-23 18:56:47 --> load:0x40080400,len:3032
2022-08-23 18:56:47 --> entry 0x400805e4
2022-08-23 18:56:47 --> Connecting to Wi-Fi...
2022-08-23 18:56:48 -->
2022-08-23 18:56:48 --> Connected with IP: 192.168.86.238
2022-08-23 18:56:48 --> Firebase Client v4.0.3
2022-08-23 18:56:49 --> Token info: type = id token, status = on request
2022-08-23 18:56:50 --> Token info: type = id token, status = ready
2022-08-23 18:56:50 --> Get integer... 0
2022-08-23 18:56:56 --> Get integer... 255 //works as expected
2022-08-23 18:57:04 --> Get integer... 128 //works as expected
2022-08-23 18:57:10 --> Get integer... 4 //works as expected
2022-08-23 18:57:18 --> Get integer... 1 //works as expected... Leave ESP32 running...
2022-08-23 19:33:53 --> Free Heap Space: 252932
2022-08-23 19:33:53 --> Get int... response payload read timed out due to network issue or too large data size
#include <WiFi.h>
#include <Firebase_ESP_Client.h>
#include "addons/TokenHelper.h"
#include "addons/RTDBHelper.h"
#define ledPin 13 // LED on Feather32
unsigned long sendDataPrevMillis = 0;
unsigned long count = 0;
int ALARM_STATUS = 0; //integer value used to determine current alarm state
* FIREBASE SETUP
// Define Firebase objects
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig config;
* For the following credentials, see examples/Authentications/SignInAsUser/EmailPassword/EmailPassword.ino
#define API_KEY "AI---"
#define DATABASE_URL "ea---.firebaseio.com"
#define USER_EMAIL "ea---@gmail.com"
#define USER_PASSWORD "rd---"
#define WIFI_SSID "GO---"
#define WIFI_PASSWORD "br---"
* Firebase Variables to save database paths
String listenerPath = "/3423---/";
String dataPath = "/3423---/status";
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(300);
Serial.print("Connected with IP: ");
Serial.printf("Firebase Client v%s\n\n", FIREBASE_CLIENT_VERSION);
pinMode(ledPin, OUTPUT); // sets the digital pin 13 as output
digitalWrite(ledPin, HIGH); // sets the digital pin 13 on
digitalWrite(ledPin, LOW); // sets the digital pin 13 off
/* Assign the api key (required) */
config.api_key = API_KEY;
/* Assign the user sign in credentials */
auth.user.email = USER_EMAIL;
auth.user.password = USER_PASSWORD;
/* Assign the RTDB URL (required) */
config.database_url = DATABASE_URL;
/* Assign the callback function for the long running token generation task */
config.token_status_callback = tokenStatusCallback; // see addons/TokenHelper.h
// To connect without auth in Test Mode, see Authentications/TestMode/TestMode.ino
// Please make sure the device free Heap is not lower than 80 k for ESP32 and 10 k for ESP8266,
// otherwise the SSL connection will fail.
// Limit the size of response payload to be collected in FirebaseData
fbdo.setResponseSize(8);
Firebase.begin(&config, &auth);
// Comment or pass false value when WiFi reconnection will control by your code or third party library
Firebase.reconnectWiFi(true);
Firebase.setDoubleDigits(5);
config.timeout.serverResponse = 10 * 1000;
Serial.printf("Get integer... %d\n", ALARM_STATUS);
// Firebase.ready() should be called repeatedly to handle authentication tasks.
if (Firebase.ready() && (millis() - sendDataPrevMillis > 500 || sendDataPrevMillis == 0))
sendDataPrevMillis = millis();
if(Firebase.RTDB.getInt(&fbdo, dataPath)){
ALARM_STATUS = fbdo.to<int>();
if(ALARM_STATUS > 0){
ALARM_STATUS = 0;
Firebase.RTDB.setInt(&fbdo, dataPath, 0);
delay(5000);
}else{
Serial.printf("Free Heap Space: %d\n", ESP.getFreeHeap());
Serial.printf("Get int... %s\n", fbdo.errorReason().c_str());
if(WiFi.status() != WL_CONNECTED){
Serial.printf("WiFi not connected... Restarting...");
ESP.restart();
