Firebase + Wemos D1 min
Hi!
I am a newbie to arduino and programming.
I need some help with my project. I am sending distance sensor data to a website called firebase (like thingspeak, https://firebase.google.com/) and I want to use this data to control a motor on another device. In both scenarios I am using a Wemos D1 mini ( microcontroller using Arduino IDE with ESP8266 Wifi chip). I have problems in receive the data from firebase.
Here is a helping manual that doesn't help me as a programming starter, maybe somebody can help me with this riddle? Recuperar dados  |  Firebase Realtime Database
Here is a part of my sending code:
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
//Calculate the distance (in cm) based on the speed of sound.
float distance = float (duration/58.2);
Serial.println(distance);
Serial.print ( " cm");
StaticJsonBuffer<200> jsonBuffer;
JsonObject& data = jsonBuffer.createObject();
data["dis"] = distance;
digitalWrite(echoPin, HIGH);
String name = Firebase.push("DISTANCE", data);
if (Firebase.failed()) {
Serial.print("pushing /DISTANCE failed:");
Serial.println(Firebase.error());
return;
Serial.print("pushed: /DISTANCE/");
Serial.println(name);
delay(200);
digitalWrite(echoPin, LOW);
delay(200);
Any help is appreciated a lot!
So, you posted the code that works to send data to firebase, but not the code that doesn't work. Didn't really want help, I guess.
Sorry you are wright the second part didn't got copied...
Here I just don't know about the right commands for getting the data. If anyone could help me with this, it would be great
https://firebase.google.com/docs/database/admin/retrieve-data
String distance = Firebase.get("DISTANCE", data)
servoAngle = (106./7.) * distance + 37; //Calculate Servo Angle from targetDistance
//for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(servoAngle); // write servoAngle to the servo __ tell servo to go to position in variable 'pos'
Serial.println(servoAngle);
delay(150); // waits 15ms for the servo to reach the position
return;
Why are you setting the value of the dis node to some nonsense value?
Why do you have a JSON buffer or object at all?
What, EXACTLY, does Firebase.get() return? What, exactly, does it put in the array that is the second argument?
Okay, I was trying to say that I don't know how to implement the code for retreiving data.
the Firebase.get actually doesn't exist. I had this thing working on thingspeak and was hoping to get anywhere with it but I don't.
the help part in firebase shows me this example but I can't make it work with my sketch
this is the help code
public static class Post {
public String author;
public String title;
public Post(String author, String title) {
// Get a reference to our posts
final FirebaseDatabase database = FirebaseDatabase.getInstance();
DatabaseReference ref = database.getReference("server/saving-data/fireblog/posts");
// Attach a listener to read the data at our posts reference
ref.addValueEventListener(new ValueEventListener() {
@Override
public void onDataChange(DataSnapshot dataSnapshot) {
Post post = dataSnapshot.getValue(Post.class);
System.out.println(post);
@Override
public void onCancelled(DatabaseError databaseError) {
System.out.println("The read failed: " + databaseError.getCode());
