I have been following a tutorial to send data to a Firebase database using Arduino.
I am using an Arduino Uno WiFi Rev2, below is the code that simply connects to the WiFi and then sends data to Firebase.
I have previously had success pinging websites with this Arduino using the WiFiNINA library, so assumed that this Firebase WiFiNINA library should work too.
#include <Arduino_LSM6DS3.h>
#include <Firebase_Arduino_WiFiNINA.h>
#define FIREBASE_HOST "compost-app-4a252.firebaseio.com"
#define FIREBASE_AUTH "QKaV81CbgJcnN5zI8mSwpzkoHcWmNIVZyRv1H4dM"
#define WIFI_SSID "VM7923466 2.4GHz"
#define WIFI_PASSWORD "mrRkhbxj5smt"
FirebaseData firebaseData;
String path = "/IMU_LSM6DS3";
String jsonStr;
Serial.print("Initialize IMU sensor…");
if (!IMU.begin()) {
Serial.println(" failed!");
while (1);
Serial.println(" done");
Serial.print("Accelerometer sample rate = ");
Serial.print(IMU.accelerationSampleRate());
Serial.println(" Hz");
Serial.print("Connecting to WiFi…");
int status = WL_IDLE_STATUS;
while (status != WL_CONNECTED) {
status = WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print(".");
delay(300);
Serial.print(" IP: ");
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH, WIFI_SSID, WIFI_PASSWORD);
Firebase.reconnectWiFi(true);
float x, y, z;
// Read IMU acceleration data
if (IMU.accelerationAvailable()) {
IMU.readAcceleration(x, y, z);
// Send data to Firebase with specific path
if (Firebase.setFloat(firebaseData, path + "/1-setFloat/X", x)) {
Serial.println(firebaseData.dataPath() + " = " + x);
if (Firebase.setFloat(firebaseData, path + "/1-setFloat/Y", y)) {
Serial.println(firebaseData.dataPath() + " = " + y);
if (Firebase.setFloat(firebaseData, path + "/1-setFloat/Z", z)) {
Serial.println(firebaseData.dataPath() + " = " + z);
// Push data using pushJSON
jsonStr = "{\"X\":" + String(x,6) + ",\"Y\":" + String(y,6) + ",\"Z\":" + String(z,6) + "}";
if (Firebase.pushJSON(firebaseData, path + "/2-pushJSON", jsonStr)) {
Serial.println(firebaseData.dataPath() + " = " + firebaseData.pushName());
else {
Serial.println("Error: " + firebaseData.errorReason());
delay(2000);
However when I Upload my code, I get the following error: (included the relevant parts)
Arduino: 1.8.16 (Windows 10), Board: "Arduino Uno WiFi Rev2, None (ATMEGA4809)"
firebase_test:37:20: error: 'WL_CONNECTED' was not declared in this scope
firebase_test:43:18: error: 'WiFi' was not declared in this scope
exit status 1
'WL_IDLE_STATUS' was not declared in this scope
Telling me that a bunch of values and 'WiFi' are not declared in the scope.
Previously when using the The WiFiNINA library, these values were not declared and just recognised as globals.
The exact code I am using seems to have been used by others on the same Arduino so I am assuming my issue is something to do with the installed libraries.
Any help is massively appreciated!
