Hello all,
I've been searching the forums and honestly everywhere on the web hoping to find a solution to my problem.
I've built a custom Arduino Leonardo clone, using the same Atmega32u4.
With this board I'm trying to use the StandardFirmata sketch to access some pins on it, with pyFirmata on a Raspberry Pi through the hardware serial (UART).
Now, I've been able to implement this approach with an Arduino Mini successfully, so I know for a fact it can be done.
I'm aware the Leonardo is a bit different regarding Serials, and that Serial refers to the USB one and Serial1 refers to the Tx/Rx pins. What i think is that the default serial used is the USB one, instead of the UART one and I'm unable to specify the one I want using the StandardFirmata .
So my question is, do I need to specify something on the StandardFirmata sketch to be able to use the UART?
Please ask any questions if my post is still unclear.
Thank you in advance.
