Hello!
I'm absolutely stuck writing Firmata firmware that interfaces with all of these components at once. I can get any 2 at a time, but not all 3.
I tried to just add servo stuff to the example "UberFirmata" I found. I've highlit my additions. This works for everything but the servo. My Processing code is really long so I won't include it, but it controls each component correctly when the firmware lets it, so I don't think it's the problem.
Copyright (C) 2006-2008 Hans-Christoph Steiner. All rights reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
See file LICENSE.txt for further informations on licensing terms.
- TODO: add Servo support using setPinMode(pin, SERVO);
- TODO: use Program Control to load stored profiles from EEPROM
#include <EEPROM.h>
#include <Firmata.h>
#include <Servo.h>
- GLOBAL VARIABLES
/* analog inputs */
int analogInputsToReport = 0; // bitwise array to store pin reporting
int analogPin = 0; // counter for reading analog pins
/* digital pins */
byte reportPINs[TOTAL_PORTS]; // PIN == input port
byte previousPINs[TOTAL_PORTS]; // PIN == input port
byte pinStatus[TOTAL_DIGITAL_PINS]; // store pin status, default OUTPUT
byte portStatus[TOTAL_PORTS];
Servo servo9;
/* timer variables */
unsigned long currentMillis; // store the current value from millis()
unsigned long nextExecuteMillis; // for comparison with currentMillis
- FUNCTIONS
void outputPort(byte portNumber, byte portValue)
portValue = portValue &~ portStatus[portNumber];
if(previousPINs[portNumber] != portValue) {
Firmata.sendDigitalPort(portNumber, portValue);
previousPINs[portNumber] = portValue;
- check all the active digital inputs for change of state, then add any events
- to the Serial output queue using Serial.print() /
void checkDigitalInputs(void)
byte i, tmp;
for(i=0; i < TOTAL_PORTS; i++) {
if(reportPINs) {* - switch(i) {*
- case 0: outputPort(0, PIND &~ B00000011); break; // ignore Rx/Tx 0/1*
- case 1: outputPort(1, PINB); break;*
- case ANALOG_PORT: outputPort(ANALOG_PORT, PINC); break;*
/* sets the pin mode to the correct state and sets the relevant bits in the
* two bit-arrays that track Digital I/O and PWM status
void setPinModeCallback(byte pin, int mode) { - byte port = 0;*
- byte offset = 0;*
- if (pin < 8) {*
- port = 0;*
- offset = 0;*
- } else if (pin < 14) {*
- port = 1;*
- offset = 8; *
- } else if (pin < 22) {*
- port = 2;*
- offset = 14;*
- if(pin > 1) { // ignore RxTx (pins 0 and 1)*
- pinStatus[pin] = mode;*
- switch(mode) {*
- case INPUT:*
- pinMode(pin, INPUT);*
- portStatus[port] = portStatus[port] &~ (1 << (pin - offset));*
- break;*
- case OUTPUT:*
- digitalWrite(pin, LOW); // disable PWM*
- case PWM:*
- pinMode(pin, OUTPUT);*
- portStatus[port] = portStatus[port] | (1 << (pin - offset));*
- break;*
- //case ANALOG: // TODO figure this out*
- default:*
- Firmata.sendString("");*
- // TODO: save status to EEPROM here, if changed*
void analogWriteCallback(byte pin, int value)
if(pin == 9)
servo9.write(value);
else{ - pinMode(pin, OUTPUT);*
- analogWrite(pin, value);*
void digitalWriteCallback(byte port, int value)
{ - switch(port) {*
- case 0: // pins 2-7 (don't change Rx/Tx, pins 0 and 1)*
- // 0xFF03 == B1111111100000011 0x03 == B00000011*
- PORTD = (value &~ 0xFF03) | (PORTD & 0x03);*
- break;*
- case 1: // pins 8-13 (14,15 are disabled for the crystal)*
- PORTB = (byte)value;*
- break;*
- case 2: // analog pins used as digital*
- PORTC = (byte)value;*
- break;*
/* sets bits in a bit array (int) to toggle the reporting of the analogIns
//void FirmataClass::setAnalogPinReporting(byte pin, byte state) {
void reportAnalogCallback(byte pin, int value)
{ - if(value == 0) {*
- analogInputsToReport = analogInputsToReport &~ (1 << pin);*
- else { // everything but 0 enables reporting of that pin*
- analogInputsToReport = analogInputsToReport | (1 << pin);*
void reportDigitalCallback(byte port, int value)
{ - reportPINs[port] = (byte)value;*
- if(port == ANALOG_PORT) // turn off analog reporting when used as digital*
- analogInputsToReport = 0;*
* SETUP()
{ - byte i;*
- Firmata.setFirmwareVersion(2, 0);*
- Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);*
- Firmata.attach(DIGITAL_MESSAGE, digitalWriteCallback);*
- Firmata.attach(REPORT_ANALOG, reportAnalogCallback);*
- Firmata.attach(REPORT_DIGITAL, reportDigitalCallback);*
- Firmata.attach(SET_PIN_MODE, setPinModeCallback);*
- portStatus[0] = B00000011; // ignore Tx/RX pins*
- portStatus[1] = B11000000; // ignore 14/15 pins*
- portStatus[2] = B00000000;*
// for(i=0; i<TOTAL_DIGITAL_PINS; ++i) { // TODO make this work with analogs - for(i=0; i<14; ++i) {*
- setPinModeCallback(i,OUTPUT);*
- // set all outputs to 0 to make sure internal pull-up resistors are off*
// PORTB = 0; // pins 8-15 - PORTC = 0; // analog port*
- PORTD = 0; // pins 0-7*
- // TODO rethink the init, perhaps it should report analog on default*
- for(i=0; i<TOTAL_PORTS; ++i) {*
_ reportPINs = false;_
* // TODO: load state from EEPROM here*
_ /* send digital inputs here, if enabled, to set the initial state on the_
_ * host computer, since once in the loop(), this firmware will only send_
_ * digital data on change. /_
_ if(reportPINs[0]) outputPort(0, PIND &~ B00000011); // ignore Rx/Tx 0/1*_
* if(reportPINs[1]) outputPort(1, PINB);*
* if(reportPINs[ANALOG_PORT]) outputPort(ANALOG_PORT, PINC);
_ servo9.attach(9);_
_ Firmata.begin();_
_}_
_/==============================================================================
* LOOP()
/* DIGITALREAD - as fast as possible, check for changes and output them to the_
* FTDI buffer using Serial.print() */
* checkDigitalInputs(); *
* currentMillis = millis();*
* if(currentMillis > nextExecuteMillis) { *
* nextExecuteMillis = currentMillis + 19; // run this every 20ms*
_ /* SERIALREAD - Serial.read() uses a 128 byte circular buffer, so handle_
_ * all serialReads at once, i.e. empty the buffer /_
_ while(Firmata.available())_
_ Firmata.processInput();_
_ / SEND FTDI WRITE BUFFER - make sure that the FTDI buffer doesn't go over_
_ * 60 bytes. use a timer to sending an event character every 4 ms to_
_ * trigger the buffer to dump. */_
_ /* ANALOGREAD - right after the event character, do all of the_
_ * analogReads(). These only need to be done every 4ms. /_
for(analogPin=0;analogPin<TOTAL_ANALOG_PINS;analogPin++) {
_ if( analogInputsToReport & (1 << analogPin) ) {_
_ Firmata.sendAnalog(analogPin, analogRead(analogPin));_
_ }_
_ }_
_ }_
_}_
_[/font]*_
