I'm having an issue with a project I'm working on. I've written software to control an arduino using a firmata connection. The arduino then controls an ssc-32 servo controller via the tx line and serial.write commands.
After about two minutes of running this program and controlling servos the arduino stops sending information. I can still see the RX LED blinking so I know the software is still sending properly, but the TX LED stops blinking.
If I reset the arduino using the reset button I can once again start my program and it works for about 10 seconds and then the arduino stops sending. Then reset again and I get about 5 seconds worth. If I completely unplug and replug the arduino in I get the 2 minutes once again.
Is there any buffer I could be filling up or any command that the arduino is waiting for or anything else? I've been scouring the internet for a few days now and can't find anything.
I know I'm not exceeding any bandwidth or power issues, since I recently got a power supply for my servos so the arduino is not powering anything but itself and the program works sometimes and doesn't work others. The hardest I'm pushing this thing is maybe 4 commands per second (each command is 3 bytes). I'm running both the incoming and outgoing serial commands at 115200 b/s (I know it's supposed to have the outgoing connection be 9600, but my software wouldn't work that way for some reason).
Anyone have any ideas? This is really starting to bother me. My project is complete aside from this!
