Hi there,
I'm using an Arduino DUE board with a HC-06 Bluetooth module connected to Serial 2 (TX2, RX2). My arduino programming looks like the standard AllInputsFirmata example:
#include <Firmata.h>
byte pin;
int analogValue;
int previousAnalogValues[TOTAL_ANALOG_PINS];
byte portStatus[TOTAL_PORTS]; // each bit: 1=pin is digital input, 0=other/ignore
byte previousPINs[TOTAL_PORTS];
/* timer variables */
unsigned long currentMillis; // store the current value from millis()
unsigned long previousMillis; // for comparison with currentMillis
/* make sure that the FTDI buffer doesn't go over 60 bytes, otherwise you
get long, random delays. So only read analogs every 20ms or so */
int samplingInterval = 19; // how often to run the main loop (in ms)
void sendPort(byte portNumber, byte portValue)
portValue = portValue & portStatus[portNumber];
if (previousPINs[portNumber] != portValue) {
Firmata.sendDigitalPort(portNumber, portValue);
previousPINs[portNumber] = portValue;
byte i, port, status;
Firmata.setFirmwareVersion(0, 1);
for (pin = 0; pin < TOTAL_PINS; pin++) {
if IS_PIN_DIGITAL(pin) pinMode(PIN_TO_DIGITAL(pin), INPUT);
for (port = 0; port < TOTAL_PORTS; port++) {
status = 0;
for (i = 0; i < 8; i++) {
if (IS_PIN_DIGITAL(port * 8 + i)) status |= (1 << i);
portStatus[port] = status;
Firmata.begin(9600);
byte i;
for (i = 0; i < TOTAL_PORTS; i++) {
sendPort(i, readPort(i, 0xff));
currentMillis = millis();
if (currentMillis - previousMillis > samplingInterval) {
previousMillis += samplingInterval;
while (Firmata.available()) {
Firmata.processInput();
for (pin = 0; pin < TOTAL_ANALOG_PINS; pin++) {
analogValue = analogRead(pin);
if (analogValue != previousAnalogValues[pin]) {
Firmata.sendAnalog(pin, analogValue);
previousAnalogValues[pin] = analogValue;
In my simple windows 10 app I try do switch the onboard LED but it does not work.
Do I need to do some special setup because the bluetooth is connected on Serial2 and not on Serial? Or do I need to tell firmata that it should use bluetooth module on Serial2? But how?
Thanks & best regards, Andreas
