Firmware Updater - Nano 33 IOT
I have a Nano 33 IOT, and for something that I have in mind to try I need to load an SSL certificate on it.
Reading around, this can be done with the Firmware Updater which is available in the Tools menu of the IDE. There is also an associated FirmwareUpdater sketch which is part of the WiFiNINA library. More on this later. There is also a CheckFirmwareVersion sketch with the same library. Running it it produces this output
WiFiNINA firmware check.
Firmware version installed: 1.2.3
Latest firmware version available : 1.2.1
Check result: PASSED
Note that the output does not make sense
Running the FirmwareUpdater sketch produces this output
Unable to communicate with ESP32 boot ROM!
Obviously this is not a good sign either
Running the Firmware Updater from the menu produces this screen from which the Nano 33 IOT selectable but it does not appear in the "select firmware" list
Selecting Test Connection produces this error message
However, the FirmwareUpdater sketch is loaded on the board and has been compiled, see above
Just to be sure I clicked on the Open Updater sketch button but nothing happens
Background information :
Genuine Nano 33 IOT - loads and runs WiFiNINA examples OK
Windows 10
IDE version 1.8.10
WiFiNINA library version 1.4, which is the latest version on GitHub
Has anyone got any ideas how to update the firmware/load SSL certificates ?
There are previous threads on here asking for help with the same problem but none was forthcoming
1200 views and no replies says it all :cry:
I think it's in the works:
Probable it's already possible to do it by pulling in the various parts from GitHub. I haven't had a chance to look at it carefully to see what that would involve. I'll try to get to it later today and will let you know what I find out.
Thanks Per
1st step, update the WiFi101 / WiFiNINA Firmware Updater plugin to 0.10.10:
  1. Delete <Arduino IDE installation folder>/tools/WiFi101
  2. Download https://github.com/arduino-libraries/WiFi101-FirmwareUpdater-Plugin/releases/download/v0.10.10/WiFi101-Updater-ArduinoIDE-Plugin-0.10.10.zip
  3. Unzip the downloaded file.
  4. Copy the WiFi101 folder from the unzipped file to <Arduino IDE installation folder>/tools
  5. Restart the Arduino IDE if it's running.
As an alternative, you can just download and use the test build of the Arduino IDE from here:
Which is a bit easier, but also means downloading the entire IDE instead of just that 7 MB plugin.
2nd step, update the "WiFiNINA" library to the development version:
  1. Delete your existing installation of the "WiFiNINA" library.
  2. Download https://github.com/arduino-libraries/WiFiNINA/archive/master.zip
  3. Select Sketch > Include Library > Add .ZIP Library from the Arduino IDE menus.
  4. Select the downloaded file.
  5. Click the Open button.
3rd step, upload the "WiFiNINA" library's FirmwareUpdater sketch to your Nano 33 IoT:
  1. Select File > Examples > WiFiNINA > tools > FirmwareUpdater from the Arduino IDE menus.
  2. Select Sketch > Upload from the Arduino IDE menus.
  3. Wait for the upload to finish successfully.
4th step, Update the SSL root certificates:
  1. Select Tools > WiFi101 / WiFiNINA Firmware Updater from the Arduino IDE menus.
  2. Select the port of your Nano 33 IoT from the list under "1. Select the port of the WiFi Module".
  3. Click the Add domain button and add the domain.
  4. Click the Upload Certificates to WiFi module button.
You can also use the WiFi101 / WiFiNINA Firmware Updater to update the NINA firmware to 1.3.0 if you like.
Thanks Per. I will give it a try
Certificates and firmware updated now after following the instructions
Yay! Glad to hear it worked.
Now to work out how to actually connect to an SSL site
Amusingly the example sketch for the WiFiSSLClient does not actually connect to an SSL site at all as it seems to have been lifted from the normal client example
char server[] = "www.google.com";    // name address for Google (using DNS)
Hi, I've had this same problem, over 6 months later. I tried the solutions above, and they unfortunately didn't work. I'm on a custom board that is a clone of the Nano IoT 33 almost, with some modifications. Any other ideas on how I can troubleshoot this? I'm on the latest version of Arduino IDE on mac and the latest version of the WifiNina library (1.5.0).
Sorry, but I have no ideas apart from following the instructions above which worked for me
It appears to me from the little I have used them that the Nano 33 range is still in something of a shakedown phase. Since it worked for him, can you try the exact same software versions that UKHeliBob was using?
That is my impression too.
I have put my 33 IOT aside for now as amongst other things I was having problems with the Serial interface, which changes automatically to another port during upload and for me it did not always change back. Whether this was the fault of the board, my USB hub (powered) or my PC (Windows 10) I never got to the bottom of
