Firmware updater, not declared I tried a solution I found here
Here is the message, I'm getting it was working until fine until two days ago. Any advice, thanks
Arduino: 1.8.15 (Mac OS X), Board: "Arduino Uno WiFi"
ESP32BootROM.cpp:335:32: error: 'SerialNina' was not declared in this scope
ESP32BootROMClass ESP32BootROM(SerialNina, NINA_GPIO0, NINA_RESETN);
/Users/JPR/Documents/Arduino/libraries/WiFiNINA/examples/Tools/FirmwareUpdater/ESP32BootROM.cpp:335:32: note: suggested alternative: 'Serial'
Serial
ESP32BootROM.cpp:335:44: error: 'NINA_GPIO0' was not declared in this scope
ESP32BootROM.cpp:335:56: error: 'NINA_RESETN' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
Hi @tubesrule. Which Arduino board do you have?
@tubesrule wrong section I have moved, it here. Please be more careful where you post in future.
You seem to use a mac so maybe the mac-version of the arduino-IDE is too puristic to have these options.
I suggest we wait for @tubesrule to answer my question. I think the way forward will become quite clear at that point.
I could charge forward based on assumptions, but I don't like to operate that way.
Guys thanks for all the replies, I figure it out. The solution was rather simple, the error code complicated the solution, was a second ground lead in the wrong spot. Reversed the project, until the leds started working again. But hey I'm learning, again thanks!!
I'm glad you were able to find the solution. Thanks for taking the time to post an update with your findings.
I'm glad I waited it out because my guess of the cause of the problem was nothing at all related to circuitry!
