firmware upgrade wifi shield
hi downloaded the Flip software, and using the strings in this page: http://arduino.cc/en/Hacking/WiFiShieldFirmwareUpgrading managed to complete the cycle with no errors. however, when running a sketch i get no wifi shield present.
before I upgraded, it found the shield, and connected to the wireless router. however it did not server the page to the ip. I was recommended to upgrade the firmware.
thanks,
Did you remove the DFU programming jumper after you upgraded the firmware?
yes
Then it appears your firmware upgrade failed. Where did you get the upgrade files? I used the files included with IDE v1.0.5. They are: /hardware/arduino/firmwares/wifishield/wifi_dnld/Release/wifi_dnld.elf and /hardware/arduino/firmwares/wifishield/wifiHD/Release/wifiHD.elf
Look at this thread, particularly reply #9. It has the output from a successful upgrade of the wifi_dnld.elf file. The second file upgrade should look identical, except the file name. http://forum.arduino.cc/index.php?topic=175173.0 Note the two .elf files had been moved to the root directory. I did the same thing.
hi, should both these files: wifi_dnld.elf and wifiHD.elf be downloaded, still getting wifi shield not present thanks in advance
Yes, both must be installed to complete the upgrade.
this is what I get, i moved the the file to C: for ease of use.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\barry>cd…
C:\Users>cd…
C:>cd program files (x86)
C:\Program Files (x86)>cd atmel
C:\Program Files (x86)\Atmel>cd flip 3.4.7
C:\Program Files (x86)\Atmel\Flip 3.4.7>dir
Volume in drive C has no label.
Volume Serial Number is 50FA-54DB
Directory of C:\Program Files (x86)\Atmel\Flip 3.4.7
02/01/2015 01:40 PM .
02/01/2015 01:40 PM …
02/01/2015 01:40 PM bin
10/08/2007 05:48 PM 18,349 COPYING_GPL.txt
02/01/2015 01:40 PM demo
02/01/2015 01:40 PM help
02/01/2015 01:40 PM info
02/01/2015 01:40 PM 60,432 uninstall.exe
02/01/2015 01:40 PM usb
2 File(s) 78,781 bytes
7 Dir(s) 285,475,770,368 bytes free
C:\Program Files (x86)\Atmel\Flip 3.4.7>cd bin
C:\Program Files (x86)\Atmel\Flip 3.4.7\bin>batchisp.exe -device AT32UC3A1256 -h
ardware usb -operation erase f memory flash blankcheck loadbuffer c:/wifishield/
binary/wifi_dnld.elf program verify start reset 0
Running batchisp 1.2.5 on Mon Feb 02 14:26:58 2015
AT32UC3A1256 - USB - USB/DFU
Device selection… PASS
Hardware selection… PASS
Opening port… PASS
Reading Bootloader version… PASS 1.0.2
Erasing… PASS
Selecting FLASH… PASS
Blank checking… PASS 0x00000 0x3ffff
Parsing ELF file… PASS c:/wifishield/binary/wifi_dnld.e
lf
WARNING: The user program and the bootloader overlap!
Programming memory… PASS 0x00000 0x2902b
Verifying memory… PASS 0x00000 0x2902b
Starting Application… PASS RESET 0
Summary: Total 11 Passed 11 Failed 0
binary/wifiHD.elf program verify start reset 0
Running batchisp 1.2.5 on Mon Feb 02 14:27:22 2015
Opening port… AtLibUsbDfu: 3EB 2FF8 no device present.
FAIL Could not open USB device.
ISP done.
Running batchisp 1.2.5 on Mon Feb 02 14:27:36 2015
Opening port… PASS
Erasing… PASS
Parsing ELF file… PASS c:/wifishield/binary/wifiHD.elf
Programming memory… PASS 0x00000 0x3fe2b
Verifying memory… PASS 0x00000 0x3fe2b
If that is true, then why this?
parsing ELF file....................... PASS c:/wifishield/binary/wifi_dnld.elf Parsing ELF file....................... PASS c:/wifishield/binary/wifiHD.elf
Are you certain you are upgrading with the correct files?
edit: Do you have an R3 model Arduino? If you have a pre-R3 Arduino, you need a jumper from 5v to IOREF on the shield or the wifi shield won't respond. If two pins on the shield overhang on each side, you have a pre-R3 model Arduino.
thanks,
i was using the Sparkfuns red board, switching to the Uno-R3, the shield worked as well as updated.
how should the shield be used on the redboard?
thanks, again
Looks like the same as the Uno. Plug it in and go.
